The sound of water running .....
Originally Posted by 3dog
Hey Doug I'm glad to see that you are still around and offering good sound advice!
I was afraid you might have left us!
Ivan
3dog
Ivan
3dog
Of course I'm still around - the lease runs till March of 06!
Plus I just know that as my luck will have it, the 06 GS will lease out cheap again and I will be back here another three years (1Sick - aka Mike, just got ill).
I am not sure if the procedure would work for GS but has worked other cars. Make sure you have colant available to add.
1. With Engine COLD take the radiator cap off (not the side reservoir, so make sure the engine is cold). Add coolant if required.
2. Start engine.
3. Let the car heat up ... till the cooling fan kicks in. (Thermostat will be open).
4. Turn the heater on. 80 or higher.
During steps 3 & 4 add coolant to the radiator.
5. Let the electrical cooling fan cycle at leat once during whih you dont have to add the coolant.
6. Tighten the radiator cap.
You are done.
Caution: Do NOT open the radiator cap when the engine is warm.
Add the coolant slowly and NEVER
add cold coolant to the radiator when the water pump is NOT running.
Salim
2. Start engine.
You are done.
![No No No](https://www.clublexus.com/forums/images/smilies/nono.gif)
Salim
2. Start engine.
You are done.
Salim
2. Start engine.
You are done.
Salim
thanks alot Salim
going to try this now
hope it works
johnny
What an awesome thread!!! I've heard the same thing in my '99 GS since I got it at 68,000 miles. I usually only hear it when the A/C is on. It sounds like water running through tubes behind my A/C vents (above the radio). I usually hear it when I just begin moving (from a stop). My dealer didn't know what it was, but said it wasn't a big deal. However, now I know what that dang thing is.... Thanks!!!!!!
Originally Posted by joshoowa
i thought it was the drain tubes in the rear... i used some electrical tape and raised it up a few inches and that noise went away... maybe its just me i dont know.
Originally Posted by doug_999
That sound will come from the sunroof and will only occur when it is raining. Closing the sunroof will make it go away (to test if that is it).
Yep, I've got it too. I've heard that it is air in the coolant lines trapped around the heater core. I can believe this as the sound comes from the dash when you first accelerate.
TLW - looking forward to your test results! If this doesn't work, I'm gonna try having the coolant system "bled" at my next alignment trip to the Lexus dealership.
i did this the other day
and im almost sure it has worked
but ill need to run more test to be sure
but next week im draining the radiator anway not too mention the other drains as well
to completely flush the system
