Is it Possible to switch out ECM/ECU(engine control module)
ive been doing somethings and no longer need to use my SRT intake
the question is ...someone would like to use it but im not really good with wiring
is it possible to just switch ECM's /ECU's =engine control unit
has anyone ever taken theirs out ??
Good Hint!!
Originally Posted by T.L.W.
how's this for a hint?
That's one hell of a hint. LOL. Anyway, If you're just removing the SRT Intake and piggyback ecu, it should be pretty easy. Only one wire is actually cut and the SRT ecu wiring is spliced in. And the rest is just tapped onto, not cut. All you have to do is solder the one wire that was cut. You should not need to swap out the factory ecu. If you did, you will have other issues to deal with, like the imobilizer. I hope this helps.
How much boost are you planning on running, and is that an SRT or RMM s/c? Did you get the whole kit or are you having someone piece it together for you? Good luck.
Will
idk for some reason I thought you posted a comment in your sig that you werent gonna get into FI coz of reliability, etc....so now your gonna do FI huh? damn....your car is gonna be off the chain haha
Originally Posted by aloha03gs
johnny,
drewgs4 posted that statement a while back about the FI
iliked what he said but im the type of guy that always needs more speed
i blame that on having had motorcycles
there is also one more thing i want to say
i have said inthe past that the RMM supercharger bracket is all you need to bolt up a blower
i dont think that true anymore i think you need 3 pieces ...atleast
1.the bracket.
2. theidler pulley system
3.the spacer for the thermostat housing
it definitley is more invovlved
-johnny
1.the bracket.
-johnny
