Throttle position sensor (TPS) malfunction?
Originally Posted by ted920
I am having the exact same Engine Light and VSC on/off light issue and loss of power and also engine stall.
i hope that its only the TPS sensor.
Is this an easy fix and how much is it to get done?
Ted
Ted
When it died, I hit it in N and restarted it again.
I couldn't remember how much was for parts, but the labor was covered under goodwill gesture at my dealership
I am waiting to receive the TPS and then will probably take it to the dealer for them to put it in.
I called the dealership to tell them of my plan and then said that they haven't replaced any TPS's on the GS but that they have seen problems with the "THROTTLE LEVER" and have replaced quite a few of those and that that may be my problem.
They quoted me $250 for the THROTTLE LEVER and then about 1 hour labor to install.
Thoughts anyone?
Ted
Thoughts anyone?
Ted
Thoughts anyone?
Ted
Thoughts anyone?
Ted
Originally Posted by slickgt1
Ok TPS on our cars is new territory for me. But couldn't you just read the voltage out of the wires comming out of it. Write is down. Bolt in the new TPS and twist it around untill the right voltage is acheived?
My understanding was that the sensor is measuring throttle blade angle, and that we couldn't do the 'voltage' method that is common on a NON-OBDII engine.
Bradster
03-31-03 05:24 AM
mdfdsc300
SC- 1st Gen (1992-2000)
03-26-03 11:25 AM
