Does the timing belt only last 5 years, regardless of mileage?
http://www.troublecodes.net/tbelt/lexustb.shtml
Lexus Timing Belts
Engine
Recommended Interval
2.5L
60,000 Mi.
3.0L Inline 6 (92-97)
(26)
3.0L Inline 6 VVT-i (98-00)
(26)
3.0L V6
(52)
4.0L*
(26)
4.7L*
90,000 Mi.
* - Interference engine.
(26) - On 1995 & prior models, replace at 60,000 mile intervals. On 1996 & later models replace every 90,000 miles or 72 months under normal service, or every 60,000 miles in severe service.
(52) - On 1990-95 models replace every 60,000 miles. On 1996-98 models except E5300 replace every 90,000 miles or 72 months under normal service, or every 60,000 miles in severe service. On 1996 & later ES300 replace every 90,000 miles or 72 months. On 1999 & later RX3OO replace every 90,000 miles if vehicle operates under severe conditions such as low speed driving for extended ranges, door-to-door deliveries, taxi or law enforcement situations.
Lexus Timing Belts
Engine
2.5L
60,000 Mi.
(26)
(26)
3.0L V6
(52)
4.0L*
(26)
4.7L*
90,000 Mi.
EV ftw!!!
Thanks for the info Johnny!
Originally Posted by Hameed
This clearly means I need to change mine (99 GS400) even though it only has 45K miles on it............
well Hameed i checked mine still looks strong
im going to replace this winter though
dont know if i will attempt by my self though lol
somethings are better left to pros
i might have to take off all the S/C stuff though
Originally Posted by AUGuy21
So is a timing belt another name for a serpentine belt? I've never been quite sure. If so, replacing this rubber belt is easy to do by yourself, right?
1 Post
They always say it better to be safe than sorry. It's a car we drive in almost every day well most of us any ways. I would definitely say change it. I'm a firm believer in that kind of stuff. The better you take care of it the better it last. I hope HIGHMILES chimes in to give us his input he went 318000 miles so that's like 5 timing belts.
The V8 engine is a non-interference engine. Right from the horse's mouth, see attached.
... a depression is built into the piston head to prevent interference with the valves.
I just had a t-belt replace after 170K & 9 yrs last summer and it was cracking. You can easily check the condition of the t-belt by removing the ignition wire cover on the driver side. It's more work on the passenger side. I am not recommending anything, just do what you are comfortable with.
I know this is the GS section but I'll add my 2 cents anyway. Had my valve cover gaskets replaced at 45K miles. The timing belt was inspected and looked new. The technician didn't even consider changing it....and he's always recommending everything. Car now has 56K miles and the last technician who worked on the car said the way I baby my car, he wouldn't recommend changing it until around 100K miles.
I'm not gonna wait that long but I'm in no hurry either.
Well, I will have mine replaced in the coming days. If you are doing timing belt, you would be a fool not to do the water pump as well. The pump is only another 100 bucks or so...but its the labor that kills you.
I am getting some of my front suspension replaced as well. All new control arms, ball joints, tie rods, during this service.
I wished daizen had those control arms made. Was really hoping to get those installed instead of OEM.
Originally Posted by Billh2
Would you trust an aftermarket belt, or stay with one from the Lexus parts department?
when it comes to important stuff like this
serpentine ..id go with any reputable company
