For the lowered GS's ,..What jack do you guys use ??
i use a small jack that i bought at autozone, nothing special. i barely get under to life my car but than agian i don't tuck the car for shows, its already low enough for me...good luck. i like the blue one !
EV ftw!!!
Originally Posted by rominl
i use the 2 1/4 ton craftman jack from sears. everyone knows how low my car is, and i have kits, and it fits perfectly under my car no problem. no need for 2x4 or whatever. good stuff
30 bucks for the jack AND two stands, what else can i ask for
Originally Posted by Hameed
I need to get me one of these!
Got any link so that I can see what it looks like?
and still needed to lift up the fender while someone took it out from underneath
Originally Posted by T.L.W.
Hameed i had bought one of these already
anyway hameed, here you go
http://www.sears.com/sr/javasr/produ...&bidsite=CRAFT
The One
man, johnny, i guess your car must be super low. with my setup i can still fit it in under the front with maybe 1/2 inch clearance
I know that I am not dropped as far as you are and the TTE lip is not that aggressive, but I cannot get my 3.5 ton jack to fit the front. I am sure the 2.25 ton jack may fit but I just like the extra security of a larger jack. Unless I am doing something in the middle of the car, I leave the jack there in addition to the jack stands (also 3 ton variety).
dubsonlexus
O.C. Lucky Strike Fanatic
What I do is take the stock jack to lift up the car 4 inches from the front tow hook.
Then I take my 2 ton floor jack that I bought from Autozone and put it under my sideskirt & proceed to jack it up.
The jack was like 30.00 with 2 jack stands and a creeper.
thanks guys
![](http://i1.ebayimg.com/03/i/02/6e/4e/c1_1.JPG)
found this one thanks to the links you guys provided
This BRAND NEW high performance aluminum racing jack lifts 3000 lbs. to a maximum height of 15-1/8''. Requires only 1/2 turn to release!
Specially designed 4-5/8'' wide, low profile, single front roller wheel for quick and accurate placement where you need it. Low profile 3'' minimum saddle height comes with 360° rotating rubber pad to prevent marring
Constructed for professional racing teams out of precision-machined, high strength, aircraft aluminum billet. Below is plain colored version . It will come in the colors as depicted above
# Minimum saddle height: 3''
# Maximum saddle height: 15-1/8''
# Handle overall length: 23''
# Two piece knurled aluminum handle prevents slipping
# Overall dimensions: 20-1/2" L x 9-3/8" W x 8" H
# Only 31.4 pounds!!!! Thats it!!! Its not your grandpa's ole jack
Similar Jacks Sold Nationally at Over $400!
Originally Posted by Neo
I think it is a combination. The UGO is not an aggressive lip plus it curves up in the middle. The 2.25 ton jacks are also small.
i just jack up the car from two sides, right behind the front wheel. that's a lot easier
Originally Posted by GS300Rich
What did you end up paying for the jack TLW? Also does the seller have any other auctions for these on ebay?
the one i ended up buying i bought aT SEARS for $88
very nice ..not as low as the ones on ebay but it works so im happy
lightweight 44lbs and the handle removes in 1 sec
on sale now at SEARS until april 9th
The Craftsman 1 1/2 ton aluminum jack looks really nice. It has speedy lift feature, 2 pumps of handle bring saddle to the chassis. $31.99 discount this week, I'm going to get one too. Thanks
yeah i like it alot
plus the handle comes out 1,2,3 and is two piece ..the handle that is
came out to be like $93 with tax
great product and if you dont like it
Sears has a great return policy
