I actually got the used ballasts off e-bay for 230 shipped, never had a problem since. I also have a spare, incase I need another one. I think they are a lot cheaper now a day's, good luck.
I have the same problem on my car 98 gs 400, let me know if you find a solution. driver side keeps popping fuses as soon as you turn the light on, it doesnt even turn on for a split second. Once on,burns fuse right away,that fuse only. please help me too....
There are only two ways to solve electrical problems ... start disconnecting load in the path of the short {if you have plenty of fuses you can start at the far end, else start at the base of the circuit and bring more stuff on line as you go.
Or
you need an ohm meter with information on what is the "good" reading to expect.
