Can i bondo Plastic?
I went to get my brake pads change today and end up with a broken lip. My lip is Greddy and its not the fiberglass one. This is plastic so my question is can i bondo it over or i have to get a new one? here is the pix how it look like
Originally Posted by tommyGS3
i had it on my car awhile back and when i brock it it was not easy to bondo. u can still see bondo part. It's easier and less effort to just buy a new one.
BTW-- i got a wise bumper now, just my 2 cents
L is this something you plan on doing yourself ??
Yea i plan to do it myself. I know its gonna be a lot of people but yea i don't wanna get fiberglass period. If i can get one that not fiberglass then less work for me.
honestly before i bought the wise sports front bumper
i had the TTe lip and really thought it flowed well
i was going to sell but just in case something happens ...i have a back up
i might just cut out the slats to show off the FMIC on the stock bumper
Ok if u attempt this yourself remember it it not that easy, also who is going to paint it after u do the repair??? With this in mind there is a product called "FUSOR " . U can buy this from a automotive paint supply store. U will also need the proper dispensing tool to flow the product<since it is like 2 part poxy .. all u really gotta do is pre fit the 2 pieces... flow the fusor over bolth ends of the repair and heat the area with a heatgun or even a "hairdryer". Once the product is dry u can sand it down with sandpaper. First use a lower grade grit paper and work ur way up to a higher one (such as a 320 -420 grit ) until u make the seam unnoticeable then u are ready 4 paint. Believe me fusor is strong enough to bond anything ... I worked in an auto body shop 4 years good luck ... it can be done but i dont recomend painting it ur self they should not charge anymore than $100 2 paint that after u complete the repair . Some shops might do the total repair for cheaper than that, but it might be of lesser quality.
thanks for the info yea i'm not gonna paint it myself my cousin gonna paint it. I wanna put it back together myself bcuz i dont' trust anyshop to do it like u said they not gonna do it with high quality.
ARISTOh
09-08-09 07:30 PM
