Removing yellow from fog lights easy?
Old 06-07-01, 10:39 PM
Erick G
Erick G's Avatar
Has anybody done this yet?
Please give me instructions please
changed all my other bulbs today and really want to get rid of this yellow
also got my springs/shocks installed today along with steering ecu
thanks
Old 06-07-01, 10:43 PM
disc108
disc108's Avatar
yeah its easy. itll take u 15 minutes.
Old 06-07-01, 10:56 PM
Erick G
Erick G's Avatar
i understand the easy part
now what are the steps to this?
i think i can spare 30 minutes
thanks
Old 06-08-01, 11:46 AM
Benny
Benny's Avatar
let me know when you hear something.
Old 06-08-01, 07:40 PM
LexusRules
LexusRules's Avatar
here its from my website, can't get more detailed than this:
Click Here
Old 06-08-01, 08:37 PM
disc108
disc108's Avatar
sasha's website is correct. however, i always omit step 2's instruction on removing the black thing where u twist 1/4 turn. i just leave it on. all u gotta go is take off foglight. remove the lightbulb, and break the glass with a screwdriver and hammer. u might have to break it @ 2 different places if possible. it might not break into big enough pieces for it to fall out, so u will have to get needlenose pliers. first, shake and position any big pieces so they are at sitting at the entrance. then all u gotta do is pull it out hard w/pliers.
Old 06-08-01, 09:38 PM
bishop
bishop's Avatar
Default suggestion
To get all the glass out, how about attaching the wide end of a cut balloon to the end of a vacuum and then a straw or tube to the narrow end. You can now actual stick the straw/tube into the foglight and suck out all the pieces. Kinda like what the dentist has.
Just a suggestion.
Old 06-08-01, 09:54 PM
biggie27
biggie27's Avatar
does anyone have a picture of the cleared out fog lamps on there car ( with HID preferably) thanks guys
Old 06-08-01, 11:13 PM
whitediamond
whitediamond's Avatar
Default took 13 minutes
Link above is down.
But it only took me 13 minutes to do. Remove the two screws. Pull out foglight assembly. Disconnect the bulb. Remove the bulb. Using a small screwdriver -HIT the yellow glass on the SIDE through the rear hold with a hammer-NOT VERY HARD.. Pull out pieces with a Long Nose. Reinstall. Just be careful that you do not hit the LENS glass with the screwdriver. It does not take much of a hit.
As stated above, there is no need to remove the black seal ring.
Old 06-09-01, 01:50 AM
MikeGS4PE
MikeGS4PE's Avatar
Anyone have before and after pictures?
Old 06-09-01, 07:35 AM
Received 2,419 Likes on 1,584 Posts
Hey Erick - what springs/shocks - and how do ya like the difference? Give us your impressions.
Old 06-09-01, 10:49 AM
mjdart
mjdart's Avatar
Default Why the yellow anyhow?
Does it illuminate better with the yellow or ?
Looks like an easy fix to remove.
Old 06-09-01, 11:49 AM
LexusRules
LexusRules's Avatar
here guys, i meant to post these on my site but haven't had a chance yet, for those of you that know, my car took a beating at the dealer and so i got a new set of fog lights, i took the yellow out of them again but this time with more detailed higher quality pics (plus the car is clean!!)
left yellow, right clear in this pic:
Old 06-09-01, 11:50 AM
LexusRules
LexusRules's Avatar
i've been looking around for some 9006 good blue bulbs but it seems that they are the most popular size and i can't find a good set! i have more pics of the installation if you want them as well.
both clear with HID
Old 06-09-01, 12:10 PM
disc108
disc108's Avatar
hey sasha, are those headlamp washers cool?
Quick Reply: Removing yellow from fog lights easy?
