Slight moisture in GS headlights.
Originally Posted by Neo
Yes. The front bumper needs to come off, though.
Is it too late to "complain" to the dealer? You just got the car.
Originally Posted by GS300Rich
I would take it to the dealer and complain. I dont know if they have to complain but maybe if you make enough noise they will replace them for you. I have heard of someone resealing them themselves but dont know if it worked ![Uhh...](https://www.clublexus.com/forums/images/smilies/1387914497.gif)
the cold to hot cycling seems to have a effect on the rubber seals
all i did was buy some clear bathroom silicone adhesive .. cut the tip at a angle but a tiny hole..the gentlty pull back the rubber just enough so you can squeeze the silicone in , make sure to have a damp pices of paper towel to smooth out the overage and just do it all the top and as much of the sides as possible.. down towards the bottom the seal does not leak for the bumper sits right on it but i do still spread a thin bead around the perimer and use the damper towel to smooth it and clean up overage..
i just redid it 2 weeks ago and no leaks again
i never had an issue on my 98 headlights but i took them apart anyway to do black-housing and resealed them up with some clear sillicone. no leaks, no moisture even after the bad winter we had here.
If i have to take off the bumper I'd rather not fool with it. The lights are not really that bad. I think I'm being annal about it. It was just alot of moisture because it rained alot yesterday when i got the car. I saw some headlights on ebay so i guess all years would fit mine? thanks
it will get worse shortly, once the seals start to allow some moisture , other parts of the seal will start to come apart , its actually better to do alittle silicone care right now while the rest of the seals integreity is in tact
Originally Posted by lexforlife
yes , i have resealed mine twice in 2 yrs and they work fine..it would have worked once but as you know gs300rich we had a pretty cold winter for florida standards this year..
I don't get why Lexus has such a problem with the moisture in the headlights. My buddy has a 2002 nissan frontier with kinda similar headlights - clear lens covering chrome - and those lights don't have the first problem like this. They pretty much look brand new after three years ... and zero moisture.
I don't care for nissan either, just saying that it can be done
