Rattle from ML Sub?
Yes Dave I searched but all I found was stuff about the SC430. Well at first I thought that it was the speaker grill rattleing but its solid. It's like a poping sound almost like a loose peace on top of the woffer. Is this common?
Yes I do still have warranty but Id rather not deal with the dealer if there is a quick fix.
Chu...
Thanks chuck ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
Im still under warranty so I'll be taking it in ASAP. Id just rather not deal with the dealer if I didnt have to. Las time I was there I got a gouge in my Salin's so bad the it gauged the tire also. I noticed it 5min after I pulled out so I didnt even boughter trying to tell them they did it just went to the closest tire shop for new rubber.
Originally Posted by GS300Rich
I have that rattle also and I think it will really suck if I have to remove the rear seat to get to it. Let us know what the dealership comes up with
just curious, does the rattle come constantly or only if you turn up the volume? on mine (stock pioneer), at low volume it's ok, but at high volume, the whole rear deck will rattle pretty bad
Originally Posted by rominl
well but you don't have ML
the ml sub is only 8", so it could be the mounting issue
Originally Posted by R1derfull
Mines comes when I turn the volume up but only on certain bass patterns though. ![Uhh...](https://www.clublexus.com/forums/images/smilies/1387914497.gif)
I had the same problem with the SUB on my SC430. Unfortunately the sub was blown, more specifically, the surrounding foam had deteriorated thus making a very annoying rattle sound. You are better of disconnecting it completely...
cshyne@msn
06-25-11 02:54 PM
