vsc for gs owners with lsd -- umm....
alright, well, so i kinda sorta learned it the hard way tonight.
i was driving my gs4 back from LA this past weekend coz' we finally sold our is300 (another story).
granted i have been driving the sc430 stock from nov to jan, and then the is300 till i just sold it this weekend, i am kinda used to "normal" cars, meaning no major power monster like my gs4.....
so i was driving my gs4 back up and took a break. got to a restaurant, rest, got out, and i had to make a left turn. the ground was a BIT wet (and i mean it, only a bit).
so i just normall gave gas to the car, not even flooring (no point to), and proceed to make the left. half way through the turn i noticed something weird, the car continued to turn left even when i steered it back. oh crap, the rear is going out @_@
i took my foot off the gas and just continue to steer (thank god it's in the middle of no where so no cars around), but to my surprise, the vsc did NOT kick in
at least not until the car almost got steered back and i *think* one of the rear wheel got traction again. then i see the vsc flashes and some braking to correct my course....
so after this, i think it's true that with the lsd, it's possibel that both wheels are spinning on turns, and the vsc will not kick in coz' it thinks the car is just going on no problem, but in reality the car is sliding out already.
damn, gotta relearn my driving with this car again..... the tc and lsd are awesome, the car is mad fast now. but you gotta know how to drive it too @_@
I don't have lsd, but vsc is crap
what's the matter Henry, you don't like getting sideways? I think GS 2nd gen VSC sucks in general.
when mine kicks in, it feels like someone just turned the key off for a second or so. I hate it.
is that how everyone's is? like if pulling into traffic, and one wheel starts to spin, it just cuts of ALL power for WAY to long.
Henry,
I have the TRD LSD and my VSC kicks in early whenever one wheel seems to spin mor than the other. If I am correct, there is also a yaw sensor that is read that may activate the VSC. I had mine changed out when I first got the car and since then the VSC "overreacts". If you do a search on the TSB for VSC it should give you some info. Glad you didn't get into any trouble
aloha
Ricky
aloha
Ricky
Originally Posted by DetMich1
Henry, glad to hear nothing bad happened as a result. As far as the VSC goes, aren't there sensors on all four wheels? You'd think the "brains" of the system would recognize when there is a disparity between the rotational speed of the rear tires and the front and conclude that some serious wheel spinning is going on.
Hope that helps...
I think GS 2nd gen VSC sucks in general. when mine kicks in, it feels like someone just turned the key off for a second or so. I hate it. is that how everyone's is? like if pulling into traffic, and one wheel starts to spin, it just cuts of ALL power for WAY to long.
Henry:
Glad nothing bad happened. Now that I have my summer setup back on, the next time it gets wet out, I'm going to play around to see how far I can push it before breaking the rear loose. BTW, what's your definition of "normal" gas.? 1/3, 1/2...
Originally Posted by NoRyceGS4
its what happens when you mess around with the original design. glad nothing happened though conservative car maker, conservative car.
Wow Henry, glad nothing bad happened. With an OPEN (stock) diff the same situation would result in the inner wheel initially spinning madly because it has no traction and then ALL the torque goes (uselessly) to that wheel (that's what an open diff does) and then VSC quickly realizes one wheel's going WAY faster than the other and shuts down the party. But with your lower gearing, Torsen diff and high stall TC you've got a lot more torque on tap than stock, and you can get BOTH wheels spinning on a slippery sharp turn like you took (because if one wheel begins to slip the torque correctly goes to the OTHER wheel) and when they're both spinning the VSC won't detect it.
Hope that helps...
Hope that helps...
i had similar incidents before the install, and the vsc kicked in very very fast and just cut all power and braked for me. basically put my car back in stand still right the way.
but this time, i made a left, half way it started to slide out, and by the time the vsc finally kicked in (long after i left go of gas) i had probably mad an 120 degree turn (instead of 90, and then the vsc kicked in and put me back on course...
truely a wake up call
Originally Posted by rheiy
Henry:
i think the ground was a bit wet (like i mentined) and maybe i turned a bit fast? dunno.
and i am amazing coz' i already have 10 in the back with 275 (and a lot of tread). granted, my daizen sways are at the stiffest settings
BananaGS
04-24-03 10:07 AM
