90K service with Lexus
Originally Posted by CinFulxGS4
UPDATE...
$1500 for...
30K service. (includes trans service and diff service
Crank Seal
Timing Belt
Water Pump
Drive belt
100K service
Loaner vehicle - FREE
$1500 for...
Crank Seal
Timing Belt
Water Pump
Drive belt
100K service
UPDATE...
$1500 for...
Crank Seal
Timing Belt
Water Pump
Drive belt
100K service
$1500 for...
Crank Seal
Timing Belt
Water Pump
Drive belt
100K service
the drive belt can be done in uner 2minutes
the trans service is very easy...diff ..id have to check ..but should be taking off cover
putting back on and refilling
johnny
if you want ill show you right now how to do drive belt in 2 seconds ..let me know
johnny
or if anyone wants to know
ill post pics and everything ..one of the easiest things to do
johnny
Please show us how to do this. Also should I go to a lexus dealer to purchase this part?
maybe some knows how to a 300 and will post up
but you can get the belt from any auto parts store
UPDATE...
$1500 for...
Crank Seal
Timing Belt
Water Pump
Drive belt
100K service
$1500 for...
Crank Seal
Timing Belt
Water Pump
Drive belt
100K service
JPI
sorry i have a 400 its different
Originally Posted by chuckb
Hey Johny(TLW)- I'd be interested in a pic of where the trans drain plug is.
whoops forgot
1.jack up car..secure with jack stands
2. pull drain plug ..let it drain into whatever you have
3.put plug back in
4. fill up with 3-31/2 quarts of toyota IV trans fluid
5.start engine check level while engine is running
6. add the 1/2 quart if needed
7. drive around and check level again should be all good
see how is easy that was
you dont have to change the trans filter ..Lexus doesnt unless they think you have a trans problem ....
start to finish 1/2 hour to hour
if you have any questions please ask
3.put plug back in
thanks Johny
wow, now I see why the dealer charges $100 for that looks real complicated(sarcasm)
that looks easier than an oil change.
ill do the drive belt DIY tomorrow
if any jersey /new york need their drive belt done let me know
free of charge
I drained and filled the AT fluid yesterday and only 2.5 quarts came out. I used a one-gallon pitcher with quart/fluid oz marker to determine how much was drained. My car was on Rhino ramps instead of jacks thus may explain why it is 2.5 instead of 3.5 quarts.
I will ask what they are doing before I take the plunge on the tranny service but I am under the impression the are changing the filter and doing a complete fill.
The bare minimum is going to be...
Timing belt - $530
Water Pump - $290
Crank Seal - $300
Total here is $1020
Show me before I take it in Monday on the drive belt so I can see if I can do the change myself...
if not I am getting this stuff for $480 more...
Drive belt
Tranny Service
Diff Service
the rest of the 30K service which includes new filters (AC too), oil change, ETC
They also said the $$$ included a 100K service (maybe they mean new plugs...)
Timing belt - $530
Water Pump - $290
Crank Seal - $300
Total here is $1020
Drive belt
Tranny Service
Diff Service
