90K service with Lexus
90K service is nothing more than a 30K service.
So, I plan on doing everything myself except for these...
Timing Belt - $530.00
Water Pump - $290.00 - $190 (part) $100 (labor)
Tranny Service - $110.00
Rear Diff Oil - waiting for a price.
and since they will have it for more than 2 hours I get a loaner, I am going to ask for a stick IS300... but I doubt I will get it.
Am I missing anything else important I should let the dealer handle? Thermostat maybe?
How does the pricing sound... I know $530 might be a little high on the belt, but I would rather they do it than save 100 bucks.
If they are going to change the water pump at the same time they are doing the timing belt they should not charge any additional labor because they have to take off the waterpump anyway to do the belt....
are they doing a complete tranny flush or just whats in the pan ??
because if you know how to do a oil change then you can do this ..its actually easier
they dont even change the filter when they do it ..or so they (lexus )told me
they just drain and refill
what did they tell you
guys
this is something very easy to do
all you need to do is jack up the car
find the trans pan
3/8 ratchet and socket 12mm or 14mm cant remember
unbolt drain plug let the 4 quarts drain
put drain plug back in
get a large thin funnel
start off with 3 quarts
start car
and add remaing quart till your good to go
4 quarts around $6 bucks a piece over the counter
half price if your a good bull*****ter
so itll either cost you $12 or $24
find the trans pan
start car
Originally Posted by CinFulxGS4
Thanks for the advice, I think I will do that myself also.
What do you think about the labor for the pump?
dont know how many hours they get for it
but on the timing belt
$530 for piece of mind is well worth it
if the T belt goes ..the engine is screwed
Originally Posted by JPI
When changing the timingbelt you don't have to remove the water pump to get to it. The dealership is right. This is a typical prices at the dealership.
JP Importz
JP Importz
sent you a PM
JP Importz
JP Importz
Just checked my handy .pdf repair manual and JPI is correct, the water pump does not get removed when changing the timing belt.
Changing the pump is a little more than just 5 bolts... so price does seem fair.
Thanks for all the info gang.
JPI, is there anything else that is getting removed that I should consider getting replaced with the timing belt... any pulley, parts, ETC????
im getting some stuff done now, i bought alternator, timing belt, timing belt tensioner, serpentine belt, water pump, crank seal, 2 cam seals, thermostat, thermostat gasket,,,,,,,,,,,i bought all parts factory toyota for a deal, only paid 500 for everything,,,,,,,,,,and i have an awesome ase certified mechanic that works at my shop,,,,,,,he is doing all labor for me for 200 dollars, im getting a hell of a deal on all that stuff,,,,,,,,,,,hes even flushing my tranny, rear differential, and changing my oil while hes at it
JPI
UPDATE...
$1500 for...
30K service. (includes trans service and diff service
Crank Seal
Timing Belt
Water Pump
Drive belt
100K service
Loaner vehicle - FREE
$1500 for...
Crank Seal
Timing Belt
Water Pump
Drive belt
100K service
