HID's or xenon's for 99 gs 400
5% Club. Killing it!!!
? How do i know if my GS 400 has HID"S or xenon lights.... All i know is that they light up the whole road and are a blue light.... Thank you I read on another search forum that the HID"S where an option for the 98-00 GS 400. Probably still is an option for the newer models
tmf I'm pretty sure they are xenon's. Thats what the dealer told me ....
The easiest way to tell is the light output and also when you first turn on your headlights. With HID's they should be a little dim at first and gradually get brighter in a couple seconds. Also the OEM HID's are more white rather than blue in color.
Second part to check is if it came from a dealer, your fog lights should be yellow. If you look at them turned off you'll notice that there is a glass plate between the bulb and the front of the foglight lens.
Hope this helps.
Hope this helps.
Originally Posted by LEXISM
well if its a 400 it came with 4100k HID's
Originally Posted by DetMich1
In addition to having the yellow fogs with the OEM HID's the head lamps were "self-leveling". When you first turn them on, in additon to taking a second or two to come up to full brightness, you should notice them adjusting the direction in which the beam points. Starts out low, pointing down at the ground and then raises up to shine further out in front of the car.
Originally Posted by Neo
Yup. This is the quickest way to see if you have OEM HIDs. The auto-leveler is nearly impossible (cost-efective-wise) to retrofit into a non-OEM HIDs car.
but i agree, autoleveling is the easiest way to tell if you have hid
Originally Posted by XenonDepot
Sometimes there are markings on the actual headlight itself. If you do have HID/Xenon headlights it may say D2R on your headlight whereas if you have halogens it may say 9006/HB4.
thanks for the info.............
Originally Posted by blacksc400
so the gs only comes with 4100K HID?
I was wondering how come my LS430's HID looks brighter than my GS's///
Your LS has a better/newer reflecter. its the flagship model my man
(runs as fast as he can from the GS forum).........
