DIY aftermarket exhaust...BLITZ NUR SPEC..mufflers only
its a beautiful day in NJ
so here we go
tools::::14mm socket ,14mm wrench ratchet....
this isnt too bad either...pretty easy
ok
jack up the car put it on jack stands
grab your wrench and socket
loosen the 2 bolts ...WD40 soak will help they were pretty tight
then remove from rubber hangers
that s it
done
2 bolts 14mm 2 nuts14mm and rubber hangers
not bad heres some pics
any question feel free to ask
up next DIY SUPRA REAR CONVERSION
here are the (2) 14mm bolt
ratchet and wrench
apart
now remove fromm rubber hangers
and thats it
now dont forget to put a new gasket ..and wear eye protection
so here we go
ok
that s it
done
ratchet and wrench
apart
and thats it
wait lol
i owned this exhaust already
but im putting a supra rear in and the exhaust needs to come down
i just wanted to show you guys how to do it if you wanted to try yourselves
Originally Posted by tmf2004
Thanks Johonny, As you know my exhaust is on back order for like 10 to 15 days... Thanks for getting the step by step process on the exhaust.... Now i have some idea of what to do so the install will go smoothly...Thanks again...Tony
let me know when you put in ill give you my number if you need help
Originally Posted by TeeLex
TLW,
Could you please measure the length of the Blitz tip - from the mounting bracket to the rear end - top of the rear if slant cut. I'm curious how long the tips are and how they would fit on my Vertex rear bumper relative to length. Thanks.
it is between 8-9 inches
