My Crazy Day ...just some pics
#32
well the rear is out
im going to say this is pretty easy
considering it was direct bolt on
im going to have the pics ups very shortly
with a sort of DIY ..i d say start to finish probably 2-21/2 hrs
if i had a lift ..***** i dont know 1 1/2 hrs
pics are on they way
with all the tools you will need
and thanks guys if it wasnt for the info on this sight i would have never even attempted to try this at home lol
ok maybe some things
picss are uploading
picss are uploading
#33
heres some of the pics
well in order to take out the Rear you need to take the exhaust from the catback off
then i took off these parts you might not have too but i thought it would make it easier
then i took out the three bolts holding the driveshaft to the rear
these bolts are 17mm ...it really helps to put the car in nuetral spin the driveshaft
and put in back into park
then i took out the 6 bolts that hold in the shafts with a 10mm hex wrench and a piece of black pipe to use as leverage
before i took out the next series of bolts i slid a jackk underneath
then i took out the three 12mm hex bolts
then i took out the two 18mm bolts up front and lowered it down
and thats all folks ..i think this is it for a while unless i decide to change the sparkplugs
or thermostat ....but the thermostat i can show you guys soon if you want
thansk again for all the replies ...made it go along that much easier
#36
Damn that's pretty.
Johnny, can I move in with you?
I'll bring my friend Mindy with me, and my tools, and my dog Dozer.
Oh, and what about the Bach. party?? yeah pics are great
but party pics are mucho better!!!
Josh
5 bucks sez he can't change his oil though.....
Josh
#38
Originally Posted by rominl
that's nice johnny. cool to see that you are putting undercoating on the rear end. the supra tt unit probably runs a lot hotter than usual, that's why all the fins for cooling
when i drained the unit there was hardly any metal on the drain plug
i would imagine with all these fins it must run hotter
next stop putting all the IC piping back on once it gets back
then off to get tuned and join the FI registry
and possible Q45 headlights ..not sure if im going to be able to tackle that but ill try at least once
tryitonce
General Classifieds
03-27-12 01:31 AM
