Opinions Please, pics inside
#31
Welcome to da club and congrats on the mods.
Those wheels look amazing on the ride. I actually planned to do the same thing but decided against it because I wanted a wider wheel and at least some sort of lip. They look great though with the color. Very nice and clean.
#32
Nice car and the rims look great on it. I am planning on going the same route w/ swapping out the stock stereo for a double din navigation unit/screen like you did (since my car didn't come w/ the stock navigation).
I was wondering how/where you got the trim ring/dash kit for the screen area of it. It matches up to the stock dash color incredibley well.
#35
#36
JungleJoe, so the dash kit came that color? did u just specify a color/year code? or did you have to paint it yourself to match the color for the rest of the dash? thanks for hte info.
#37
#38
Originally Posted by JungleJoe
no distortion what so ever... This is by far the cleanest (highest quality sound) system i have built. Been a sound enthusiust since my teens. Every part of the rear deck has been dynamatted, top and underside. I have a cutoff off 40hz to the free air while the JL enclosed is cuttoff at 100hz. While the JL provides for the mid-low range, the free air completes it with the very low-end. Just have to be carefull when setting the gain level. The free-air only sees about 3/4 the level of gain compared to JL. This ensures the free-air sub will never reach anywhere near it's Xmax during higher volumes and provides very nice responses during moderate and lower levels.
I can't be heard from 3 blocks away and that was never the intent. The sound quality however, would keep Bach and Mozart in their seats for hours.
Really!!! Very nice!! I am very interested in this same setup. My Kicker solobaric is not what I am looking for, the sound is not really what I want, but I had the sub sitting in the house so I figured why not.... I am looking at changing it already, been a couple weeks.... Where are you located?
#40
That said and you want a clean sounding system, make a sealed enclosure to the minimal specs of the sub you choose. Mine was 1.00 - 1.5 cubic ft (i think). so i made the box at roughly 1.1 cubic ft (.1 to take care of the driver's volume displacement. no polyfill)
There are those whom build a sealed box beyond specs as to get that deeper note extension, but inturn lose out on the "punchier" notes. My JL has a very nice "punch" to it with a clean deep note at moderate levels, this is where the free-air takes over. At moderate-medium listening levels the free-air provides that extra extension of deep bass. At higher-gut wrenching volumes the JL totally takes over and this is where you need to make sure that the maximum level played will at no point cause the free-air to travel beyond its maximum excursion level. Sound is still being produced by the free-air but all that is heard is the sealed driver.
I hope this made sense, i was trying to be as clear as possible.
I am in the OC area os So CAL.
#42
I understand box styles, enclosure space, etc. I was planning on running 1 sub and the freeair. My ideal goal is to have the freeair on all the time and have a toggle for the sub in the enclosure. This way I can turn it on and off as needed. When taking clients out to lunch, dinner, etc. I do not want to have the loud boomy bass, just clean and accented low notes. Does this make sense?
With that being said, what freeair sub are you running? And for the sealed I was looking at the 10w6 or maybe a 12w6.
This also comes with another thought. Did you ever just run the sealed sub, or did you upgrade them both at the same time? I was thinking about running a 10w6 or maybe a 10w7 in the rear deck and build an enclosure around it and use closed cell foam to make it a tight seal where the rear deck has more curves, etc.....
I wish you were up here in NorCal so I can check it out. But oh well...
#43
As far as building an enclosure for the back... I've thought about it and really couldnt see a way of doing it without a mickey mouse badge. You must remember that the enclosure is just as important as the Sub. I don't see any practical way of providing for a solid and extremly rigid structure a sub enclosure requires. Even if there was a soild way of fiberglassing it, the asthetics that will result is a big hump hanging from the rear deck and the only way to make it look right is to total enclose that whole portion of the trunk. Why not just keep it free air and have a sealed enclosure? I shelved that idea within a few hours.
I am running the old school Kicker FS10 no longer in production but available on ebay. Running a non free-air sub in an infinite baffle enclosure will yeild very poor results no matter what brand of sub you are using. The enclosure is just as important.
hope this helps.
