"WHY!?!" (do you NEED your master key to program a new one?)
Old 04-24-05, 05:30 PM
  #46
maaloxx
maaloxx's Avatar
Originally Posted by tamicalhou
What year and model is it?
Tami
I have a 1998 GS300.
Found this searching...will it work is my "valet" key is programmed as master!
1. Open driver's door, keep it open and in the unlocked position. All other doors should be closed and locked.
2. Put original master key in ignition and pull out. This is the only step which requires the original key.
3. Lock and Unlock the driver's door 5 times, using the manual lock, NOT the power lock. Complete each lock/unlock
cycle within 1 second and the entire process in 40 seconds or less.
4. Close the door and open the door
5. Lock and unlock the driver's door another 5 times. Complete each lock/unlock cycle within 1 second and entire
6. Put the new master key in the ignition, turn it to "on" and then "off" (with 1 second) and remove from the
ignition
7. Press and hold transmitter LOCK and UNLOCK buttons simultaneously for at least 1.5 seconds,
and then within 3 seconds, press Lock or Unlock for at least 1 second
8. If within 3 seconds, door locks cycle one time, new transmitter code was accepted. If door locks cycle 2 times,
new transmitter code was not accepted. If code was not accepted, retry step 7.
Old 04-25-05, 02:12 AM
  #47
rominl
exclusive matchup
rominl's Avatar
ignition
umm..... i thought the difference between master and valet is the "teeth" on the key, not the program inside?
Old 04-25-05, 04:11 AM
  #48
tamicalhou
Lexus Key Specialist - Sponsor
tamicalhou's Avatar
Maaloxx,
Those are the instructions for programming the remote portion of your key. There are seperate instructions for programming the transponder portion. I will post those shortly.
I still don't understand why you think the key you have is a valet key. You didn't get back to me on any of the questions I asked you... about the security light and does it work in the trunk and glove box.
I think maybe the biggest confusing factor is this.
Normally, Lexus doesn't sell non-remote masters. The Lexus dealerships call the non-remote keys valet keys. This isn't the case in the aftermarket.
There are a couple of differences between valet keys and master keys.
1) A true electronic valet key can't be used to open the programming sequence.
2) On some valet keys, for the LS430 for example, they have a different transponder chip inside.
3) The difference between a valet and master on a short key (RX300 for example) is the groove running down the side of the key. On the master there is a groove and on the valet there is no groove.
4) On the older cars and those with the long key blade the difference is the very last cut on the key.
Your car doesn't have the option of having the ECM reset with a scan tool. It either needs to be replaced or reflashed.
Take care,
Tami
Old 04-25-05, 09:24 AM
  #49
Billh2
Billh2's Avatar
Default Problem solved
The local Toyota dealership took car of my key programming issue this morning. At $36.00 per key for five minutes work, it was very expensive. BUT - it was cheaper than the 140 mile trip to Lexus of Seattle that I was planning.
Old 04-25-05, 11:23 AM
  #50
maxi-milli
maxi-milli's Avatar
Default re
Gary (maaloxx) they are asking you questions but your not answering back. What are you doing!
Sorry to hear about them breaking in your car Homie.
Old 04-25-05, 11:39 AM
  #51
Billh2
Billh2's Avatar
The locksmith who attempted to program my keys said that the problem was the security system was not switching to the programming mode. He based this on the fact that the security system light flashed at the same rate when a non-programmed key was inserted as it did when no key was inserted. I have been told that the only time the procedure of pressing the accelerator petal and brake petal works on a 2001 GS430 is when the ECM is replaced. I don't know about this. I do know that I spent HOURS attempting to get the *&##$ car to recoginze the *&##$ keys. I tried every possible combination, going so far as to time each step. (Thought I was possibily going too fast) All without success. It took the Toyota tech (They also told me this guy has extensive Lexus training) about ten minutes to get both keys to start the car. ??
Three absolute truths of Computer service:
He who touches is last, loses.
No good deed ever goes unpunished.
The truth, while interesting and amusing is irrelevant. Perception is everything.
Old 04-25-05, 04:58 PM
  #52
maaloxx
maaloxx's Avatar
Tami: Sorry about that...I don't have my car to check the security light. Hopefully I'll be getting it back tomorrow.
The Reason why I was calling it a Valet Key is becasue of the way that it looks, plus lexus told me that it was. When I told him that was the only key that I had and that I could open everything and start the car...He was confused, and said that wasn't possible.
MaXi-Milli: Way to put the fire under my ***...LOL We gotta hook up and drop my car. I'm gonna keep it and get some 20's and a TTE lip.
Old 04-26-05, 04:27 AM
  #53
tamicalhou
tamicalhou's Avatar
It sounds like the locksmith that was working on your car had no idea what he was doing!
What procedure were you using when you were trying to program in the keys?
The 2001 GS430 has the option of having the immobiliser reset using a scan tool so you will never need your ECM replaced or reflashed for lost key situations.
Here are the instructions you should have been using to program in the transponder portion of your keys.
Tami
Attached Thumbnails "WHY!?!" (do you NEED your master key to program a new one?)-2001gs430.jpg
Old 04-26-05, 04:31 AM
  #54
tamicalhou
tamicalhou's Avatar
Ok. I have heard so much misinformation come from the dealerships when it comes to keys that it isn't even funny.
More than likely you have an aftermarket master key. The dealerships don't recognize these as master keys because when they think of master key they think of the remote head keys.
Check the security light when you can. This will tell you all you need to know.
Take care,
Tami
Old 04-26-05, 10:52 AM
  #55
Billh2
Billh2's Avatar
Tami
The locksmith had that exact program and could not get it to work. I also worked with it for hours without success. Apparently the option you mentioned is not activated on my car. Probably still isn't.
We are pretty much at the mercy of the dealerships, or "stealerships" as someone has referred to them by. Maybe someday someone will figure out modify a scan tool to access these protected features.
I really want to thank you for trying to help me with this.
Bill
Old 04-26-05, 11:17 AM
  #56
slickgt1
slickgt1's Avatar
Bill
no, youre not. Talk to Tami, see if he can reprog it for you. Worst case scenario, i can ask my frined what he will charge your for this.
Crap, just noticed that you are in washington. Cause driving up here to get this done, would be the best bet, but you may just have to ship it.
Old 04-26-05, 12:12 PM
  #57
tamicalhou
tamicalhou's Avatar
Bill
The timing is critical when you do it on board. The locksmith industry already has software to program in keys for Lexus, Toyota, Nissan, Mitsubishi, Ford, Chrysler, Subaru, Mazda, VW, Audi, Honda, Acura, Infiniti, etc.
On the Toyota/Lexus software we get to bypass the SEEDCODE which is usually needed in order to program keys so we can do it without the help from the dealership.
If you had been my customer and the OBP didn't work within a couple of tries I would have hooked you up to the computer and programmed in the keys.
Were you trying to do this programming with a master key?
Take care,
Tami
Old 04-26-05, 01:42 PM
  #58
Billh2
Billh2's Avatar
Take care,
Tami
Tami
If all of the black keys that will start the car are master keys, the answer is yes. (I qualify that because somewhare I was told that there is only one master key, and the just because you have a black key doesn't mean it's a master key. Probably fiction.)
Anyway, the Toyota guys took car of it. The SEEDCODE wouldn't be that metal tag that was attached to the valet key, would it?
Thanks
Bill
Old 04-26-05, 02:03 PM
  #59
tamicalhou
tamicalhou's Avatar
Tami
Thanks
Bill
The numbers on the metal tag is the key code. It should be a number between 40000-50000. The SEEDCODE is retrieved while the computer is hooked up to the OBD2 port.
No, not fiction. It all depends on HOW the keys were programmed in. You could have a black key that is programmed in as a valet key. (certain models this is not true as the programming is the same but the chip in the key is different.) You could have a grey key that is programmed in as a master key. You could have a remote head key programmed in as a valet key. The security light is the indicator as to how these keys are programmed in electronically.
Anyway, glad you got it taken care of. How did the tech program them in? With a computer or on board?
Take care,
Tami
Old 04-26-05, 02:05 PM
  #60
tamicalhou
tamicalhou's Avatar
Correction... I'm a she. LOL
Tami
Quick Reply: "WHY!?!" (do you NEED your master key to program a new one?)
