60k service??
Originally Posted by T.L.W.
i can if you want one
ill have one up tonight![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
Originally Posted by rheiy
I'd like to see that as well. When my 3.76 was installed, the tech filled it up while the diff unit sat on the work bench. Once that thing was installed, it looks real tight to get to the re-fill plug unless you have the car on a lift..
well then we have a problem
you will need to jack up the rear of the car
is that something you want to do ??
Won't jacking up the rear cause the car not to be level and as such, harder to drain all the fluid?
or if you want to put the car up on 4 jackstands
i dont really see another way
you will still be able to drain and fill or just check
the way i was taught to check the fluid in a rear was too open the check
and put your finger in ...if you can feel fluid ..good to go
but if someone has a diffrent way by all means post up
always looking for theasier way to do things
Originally Posted by Lettuce
What about adjusting valves, is that included in the 60k service?
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
the belts are replaced
the fluids are getting flushed
valves adjusted
and there is a whole bunch of other useless stuff too.
