Where do i JACK the car up at?
Hey ya'll,
I have tried searching and no luck, (my comp might be buggin') i need to know the proper area to lift my car to change tires! Almost everytime i lift the car i hear something crack or bend so i have to lower the jack and try again but i still dont know "What area is made for lifting"
Any help Would help because i change my own wheels.
Thanks
~Kia
Thanks
~Kia
yeah i do but i swear it showed something like the outer lip like right under the sideskirt area, i believe i tried that once and heard a crackin noise!! But i will double check the manual.
BTW: im using a standard 3ton jack not the lexus one so will this still apply?
Thx Kia
Thx Kia
it should apply
i use a Sears jack and it works great
let me see if i have some pics of my car lifted
no good
i can take some tomorrow if you want
no good
Ok, right behind your sideskirts, there should be a long piece of metal that runs the whole length of your car. It sticks out a little bit lower than your stock sideskirts, just feel with your hands, you could even see it if you look from below. Anyway, right near behind the front tire, this metal piece should have a notch to put your jack on to. I always use a piece of soft wood (any kind of wood would do usually), place the wood on top of the jack and then place the jack where the notch is and just jack it up. The wood will "cushion" the force of the jack against the weight of the car. It will not bend anything, usually pretty safe against sideskirts and if anything cracks, usually only the cheap piece of wood will crack.
The notched metal thingy will exist on all 4 corners. If you have the huge scissor-type jack, then it's always best to jack the car from the front or the back using the chassis as the mounting point. The chassis points are the strongest thickest part of the car. Believe me, you will not be bending or breaking anything here.
T.L.W i will take a look tomorrow and see if i see what you and jtanoyo1 are talking about. i believe i have a idea i just didnt think that little "ledge" looked safe and i didnt want the jack to slip. i will take a look in the afternoon and re-post.
Thanks for the help for now!!
~Kia
~Kia
Also, on a side question, if you lift it from the back, would it be possible to replace the mufflers, or would you have to lift the car on both sides to do that?
Originally Posted by Lyrical
Do you still have that picture of where you jack up the car at the front / back?
I will try to take some pics later for ya. But if you jack from the back you can definitely remove the mufflers easily, no need to do from the sides....
Thx Kia
Thx Kia
ah haah! i found ya. lol. man, i remember when u first came to cl. do u remember? back when u didnt even have pix of ur car yet! wow...time flies! how r u? umm..sorry, but my post has nuthin to do w/ jackin up ur car! lol.
I do not think that the lip is where you should be jacking up the car. The lip is for supporting the car or something like that. Jacking up the car is on the frame that runs deeper into the car. For example it is beind the front wheels and a little to the rear. The rear jacking point is behind the rear wheels and a little to the front.
Look at a shop do it for example.
Can you imagine a shop picking up the entire car, with those huge lift arms by the little lip near the skirt. Not only will you bend the lip, but you will probably brake the skirt. The jacking points are deffinatelly deeper into the body.
Originally Posted by Neo
This is a pic of the SC but the location still applies to the GS.
I know when I lifted my car it was creaking and stuff and I got nervous......but I kept on going and I was fine. There are some notches under the car that sort of guide you.
Good luck Kia!!!!!!!
The One
Originally Posted by chicagoblknazn
I don't think this is the jack hat she has.
In a pinch, if you need to jack the front of the car up to get a larger hydraulic jack into the middle, because you are low, the tow hooks is strong enough to support the car too. Although it should be OK, I only use the hook as a transitional jack point.
