DIY: Retrofit Altezza pedals into your GS/Aristo
went to local lexus dealer all parts can be had roughly $160.xx
(gas pedal, gas lever, brake pedal, bolts, mounting brackets, etc)
called some local salvage yards all parts can be had $150
i tried to haggle the salavage yard but they wouldnt go lower, 10bucks more for brand new pedals hmmm weighing the difference
Guest
Posts: n/a
Jon, this thread rocks!
That is a great mod that you can DIY. Thanks for the great write-up.
I had the Levoc aluminum pedals but they had to be put over the stock pedals. The dead pedal was nice, not sure if you want to add that and it covered the plastic part in the footwell.
![](http://www.importscene.com.au/images/monza_pedals.jpg)
Very nice mod and very good write-up, thanks!!!
Originally Posted by aloha03gs
very nice man! it certainly gives the car a little more sportyness to the interior...what makes your car soo impressive is that you mod some parts of the car that normally people dont address
cody
cody
I decided to try this out. ordered my stuff and it cost me about 85 brand new. So I guess we will see if the IS pedals (not Altezza as jtanayo used) will fit on the GS
Originally Posted by jtanoyo1
Don't forget. You also need to change the metal bar that holds the gas pedal. So you need 3 parts total. You can't reuse the old metal bar from your old gas pedal. Otherwise, believe me, it's a 15 min job tops.
Originally Posted by KRGS4
Part numbers For this mod?
U.S. Lexus part numbers...I'm dying to do this...
btw. I thought the Brake pedal only needs the Pad and not the whole Brake Lever arm?
The One
I will have to revisit this. Although I did no tunbolt the GS ones, the IS ones did not seem to line up the same. The mechanism also seemed different. Did your throttle change in terms of response, Jon? Meaning, did you have to press harder or softer for a similar response on the OEM GS pedals? Also, the GS pedals pivots while the IS ones don't.
It has been months since I looked at this though. I've been driving around with just the brake one on.
And yes, neo, the IS gas pedal metal arm does not line up exactly in the GS. Like in my aristo, it shifts a little bit to the right, but pedal feel and everything else is identical.
