which wideband to go with
Old 05-08-05, 05:02 AM
QuikLex
QuikLex's Avatar
I've heard of people JB Welding the new bung on...wouldn't recommend it though. Welding it on is def your only option. Any muffler shop can do it for you for under $20.
Old 05-08-05, 05:22 AM
TLW
TLW's Avatar
so basically drill a hole..... weld and your good to go ?
nice ...thanks a lot man
Old 05-08-05, 05:27 AM
QuikLex
QuikLex's Avatar
You got it...well, atleast for the new o2 sensor part.
Old 05-08-05, 11:42 AM
TLW
TLW's Avatar
ok
center vents are out
very easy to take this out
i put a piece of tape on the end of a screwdriver as to not mess up anything
and just pried caqrefully on both sides ..time to take it out 13 seconds maybe even faster
then just disconnect the clock and hazard button and thats it
now how im going to do this ....
any help from CL members would be great
i have the pics of what i want to do already
3 gauges across ........and a wideband
thats it
Old 05-09-05, 07:00 AM
ted920
ted920's Avatar
Best of luck with the project.
I'm drooling over your car!
Ted
Old 05-09-05, 08:00 PM
TLW
TLW's Avatar
ok i bought an extra vent
what do you think of this a setup
make some vents that would go around the gauges somewhat
very very crude but thoughts please
Old 05-09-05, 08:54 PM
LXOGOOD
LXOGOOD's Avatar
Actually, that's a very similar idea Luxury Motorworks had in mind when they wanted to do my setup. We were going to use 3 gauges in the vent area and make slots for the air to still come out. However, my buddy who did my audio setup thought it wouldn't be wise to lose my vents due to the hot Cali weather so I had him create my own custom gauge pod in the cup holders angled towards me.
Old 05-09-05, 08:58 PM
TLW
TLW's Avatar
ok so im on the right track
any other insight into this
just trying to make this happen
i might have to switch gauges now because Blitz ..i think... the BLM series ..doesnt have a Trans Temp
so i want ..boost..oil pressure ..and trans temp
thoughts
Old 05-09-05, 09:40 PM
jtanoyo1
jtanoyo1's Avatar
My redirected air vents still produce the same amount of cool air. And trust me, living in the tropics 365 days a year, I KNOW that i never want to lose center air vents. So what my audio guy did is just to block off half of the center vents and mould fiberglass to reroute the airvents to the bottom slot holes....
Old 05-09-05, 09:53 PM
TLW
TLW's Avatar
thats funny
exactly what my neighbor and i were thinking
jon and lxogood thanks for all your help
Old 05-09-05, 10:01 PM
LXOGOOD
LXOGOOD's Avatar
that figures! See, if you would have finished your project while I was working on mine, I would have done it that way. But I was to chicken to lose any cooling coming from the center vents. Now at least TLW knows it works and can do it...
Johnny, I still think you need a fuel pressure gauge. Again,this is only if you plan on playing with different pulley setups for more boost. If your wide band displays lean #'s under WOT, you are going to need to find out if your fuel pressure is dropping under full boost or if you need a secondary fuel pump or larger fuel pump to keep the fuel flowing. As you already know, running to lean for too long = Boom. Just my opinion.
Old 05-10-05, 03:44 AM
TLW
TLW's Avatar
hmmm ..ok thanks ...i idnt think of that
so boost,oil pressure and fuel pressure and a wideband
thanks
Old 05-10-05, 06:28 AM
morris
morris's Avatar
are these the right ones
seems a little cheap
http://www.horsepowerfreaks.com/view...Displays~.html
Those are cheap becuase they are only the displays, I am almost positive they dont include the O2 Sensor or anything else. I have the AEM it was around 400.00, for the complete system.
Old 05-10-05, 06:45 AM
LXOGOOD
LXOGOOD's Avatar
thanks
That looks much better. You can always put the tranny cooler in another location.
Old 05-10-05, 06:45 PM
TLW
TLW's Avatar
just so you guys know
the Kazz sports pod gauge will not fit american Gs
Johnny,
Thank you for your inquiry. I have been told that the gauge pod will not fit American cars but I am investigating this matter. I will get back to you in a few days.
Thanks,
Sam Remis
Kazz-Sports
___________________________________
Johnnly,
I just got confirmation that the gauge pod cannot be installed on American models.
Please let me know if you have any questions.
Thanks,
Sam Remis
Kazz-Sports
Quick Reply: which wideband to go with
