gs430, noticing rough idle?
I really don't see this as a major problem. i think this is basically lope from the cam. Think about it. This engine has more output per liter than a Z06 vette. All that really needs to be done is up the idle speed 100-200 rpm.
I think we are all spoiled by how smooth this engine normally is.
Let me know if you know of a way to raise it and keep it there.
I too have a 01 gs 430, bought with 47k miles, bone stock. Noticed low idle prob about a month after buying it. I know have 55k and an injen intake and torquemaster plugs and cleaned the TB, but still does it. All I know is it is not a maintenance issue, like some of the other threads claim it is. It's annoying as hell to me.
I have since called a whole lot of mechanic friends regarding this. A few have suggested that it could be the engine mounts. Ours are supposed to have this engine vibration suppressors mounted to the mounts. This is supposed to help with the vibrations. And this problem may not be idle related at all. They are saying that the idle is always adjusting, and the lexus is supposed to open the AIR valve for more air, if something is clogging it up or making it stick.
The problem is, why would the vibrations stop when the idle increased? Maybe those dampner things are working better, or maybe they are messed up and cannot compensate at that low idle anymore.
Anyone have any thought on this?
exclusive matchup
Originally Posted by slickgt1
Ok, and how would you go about raising the idle. Everything on this car is computer adjusted. If you are to open the Idle Air Valve, it will be only temporary. The computer will learn this and lower the idle. That is why the GS400 people are the only ones that can even adjust it slightly because the still have a throttle cable. GS430 is electronic/servo controlled.
3UZ-FEEEE
Its all physics. When the rotation of an object equals the rotation of........... I know what it is, but cant really explain it that well. The same issue can be felt with driveshaft problems.
Guys I also have same issue and noticed it yesterday. I just bought the car 2 days ago. I have 01 gs430 with 84k. And you right, when the car has AC on it is ok and idle goes up and there is no vibration. When AC is off i have slight vibration on a steering wheel and the arm rest whem the idle goes down a bit, I mean it is not that bad, but for Lexus it is, I mean we bought this car for performance and quietness. I mean, I just sold my Bimmer to get into something as fast, but quieter, and more reliable. So, I would also take some suggestions. I do not know about these grounding kits. I am about to install a system in the car, maybe that will clear the issue. Also, SLICKGT1, I also have a problem with barrings I think, we have same millage on our cars. When I go over bumps going straight or turning slightly I get this loose feeling in the steering wheel that something in the front axle is not tight. Is that what you have?
If the groungind kit does nothing for me, i will have my shop diagnose this. They have done some miraculous things for me before hand.
OK for those that care. This is what I have done so far.
I have changed engine oil, oil filter, tranny drain and fill (twice). K&N air filter, denso iridium spark plugs, cleaned TB, installed the Teck grounding kit. Vibration is still there. But i have come up with a theory.
I have noticed that the vibration is only in drive. In reverse it is perfect. I think that this is due to some bushings/mounts being worn. I also think this is somewhere in the rear of the car. What i would like to ask you guys where there are bushings/mounts in the rear of the car. Like around the diff, drive shaft, something.
