easiest way to separate headlights
you and i both
im going to follow soaristo plan
i have some HID lights coming if i win the ebay listing
id really like to be able to have the autoleveling function
i bought halogen lights to practice ...so when i go to do it for real
i have a better idea of what to expect
The One
Originally Posted by Neo
You are going to attempt the auto-levelling? Man, even the dealers are hesitant to do this. Unless you have HIDs already, you will need more wiring and sensors. Noone I know has attempted this so you would be the first.
Johnny has OEM HIDS so his car already has all the wires and sensors.
what happened ..did you ever get them apart ?
You're attempting for auto leveling too? You're nuts.....all i can say lol....
Good luck
You having a hard time? mm just put your oven on 265 degrees and let it pre heat, once its pre heated stick your headlight in there for about 10 mins you can actually pull them apart in the oven to see how sticky the glue is ( remember to unscrewd the 3 bolts holding the lense to the housing in the back ). Once the glue is soft enough just pull em apart and have something like a couple pens near you to scoup up the glue b/c it will get all over the place and dont worry its not a big problem unless you get it on your reflective piece b/c that glue comes of easy with goo gone. And for he bumper you dont need to take it of at all. What you have to do is depanding on what side your doing if your doight ur left side then turn the wheel to the right and vise versa. Once you have clearence unscrew the plastic screws holding the mud guard in front of the wheel and pull the plastic back there you will need to remove 3 bolts one is near the side marker and the other 2 are deeper inside but you can see them. Unscrewd all those and 2 on the bottom to get the mud guard on the bottom of from your bumper and open the hood and unscrewd the bolts holding the headlight on top and then you can pull the bumper back enough to get your headlight of.
Originally Posted by joshoowa
TLW ur doing q45 projector mod right? if u dont mind me asking how much is the avg for the whole kit projectors, bulb, ballast
im weighting q45s to s2ks
bulbs ive seen for 70 a pair
and ballast no idea
well ive seen the projectors go for sale for 150 a side to 550
and ballast no idea
and ballast no idea
