easiest way to separate headlights
Old 05-12-05, 05:21 PM
TLW
TLW's Avatar
Default easiest way to separate headlights
what is the easiest way to do this
really like to separate the lense tonite
help please
tried searching ...but couldnt find an answer
Old 05-12-05, 05:40 PM
TRULUX
TRULUX's Avatar
oven at 250 for like 5 min. make sure you watch it and take off all of the hardware. is that what you are asking. to do a head light mod.you might have to redo the oven thing acouple of times. i have used a hiar dryer for the rears but the oven worked way better.
ps dont take off the clear cover on the level,
Old 05-12-05, 05:51 PM
TLW
TLW's Avatar
Originally Posted by lexsc400
To clean your headlights, you have to seperate the backing from the cover. Beforehand, remove as many plastic or rubber nozzles from the assembly as possible. They should pop out with a little force. Leave the optics in place. Once the headlight is prepped, preheat your oven to 350 degrees for 8 minutes. After 8 minutes, turn the oven off and place your headlight assembly inside. Put it on the highest rack away from the hot burners. Let the headlight sit in there another 8 minutes or so and remove it. The rubbery adhesive around the edges should be very soft. Use a clean blade, screwdriver, or straight edge to pry the cover apart from the backing. There may be plastic clips that are holding them together too. Make sure you don't contaminate the adhesive with dirt or oil. Once you have to two pieces apart, use a light cleaning fluid and wash the cover and free-form reflector. Don't mess with the optics. When you're satisfied, just do the removal process in reverse.
thanks trulux found this too
Old 05-12-05, 05:53 PM
TRULUX
TRULUX's Avatar
it was kind of weird when you said you could not find it. i thought you where sick. when i did it twice i serched oven.that seemed to work.
Old 05-12-05, 06:08 PM
TLW
TLW's Avatar
LOL
yeah ....used the wrong words
thanks again
johnny
they are in the oven right now
Old 05-12-05, 06:29 PM
rgarjr
rgarjr's Avatar
Sounds like someone is having headlights for dinner tonight.... j/k
Old 05-12-05, 06:54 PM
TLW
TLW's Avatar
they are apartt
the oven trick worked like a charm
was able to also take the amber out of the turn signal
but i guess you guys all know that one already
thanks again guys
and thank you CL advanced search
Old 05-12-05, 07:10 PM
TLW
TLW's Avatar
this is just a joke
this isnt how im mounting it
but it made me smile
Old 05-12-05, 07:16 PM
GammaLex
GammaLex's Avatar
If you have any Qs johnny im on aol. Im in the right state of mind too
Old 05-12-05, 07:17 PM
TLW
TLW's Avatar
thanks A
will do
Old 05-12-05, 07:21 PM
dmodstl
dmodstl's Avatar
Post
Originally Posted by T.L.W.
this is just a joke
Do you smell what the TLW is cookin?
Nice aim. A little more to the left oughtta do it.
Old 05-12-05, 11:50 PM
Lyrical
Lyrical's Avatar
glad you had more luck with the oven than i did lol
Old 05-13-05, 08:54 AM
LEXISM
LEXISM's Avatar
cant wait to see them where there done !!
Old 05-13-05, 08:56 AM
TLW
TLW's Avatar
what happened ..did you ever get them apart ?
Old 05-13-05, 09:04 AM
TRULUX
TRULUX's Avatar
well glad to see you got them apart. cant wait to see the fineshed product.
Quick Reply: easiest way to separate headlights
