Newbie needz advice-17" or 18"
Hi,
Im new here so dont shoot me!!!
I just got a 03 gs430, and im thinking on gettin some new wheelz. I wanted 17's so the ride quailty is still good, but I really like the way 18 look. What I was wondering is if i get the 17 with 215/45/17 will it look to narrow?
Here is what they look like.
17" gunmetal
And here are the other wheels im looking at.
18"/7, even more narrow.
Thoughts, comments?
Thanks in advance
17" gunmetal
Thoughts, comments?
Thanks in advance
I would go with the 18's especially if you are going with a wheel that has a "lip" like you have shown. Actually, I'd recommend staying away from a lip to make the wheel appear even larger. The large body of the GS tends to dwarf most wheels.
For tires you need to go wider. 235 and up.
20"
... oh, I'm sorry, what was the question?
Seriously, you'll need to do 18s to even consider this an upgrade- after all, the GS comes with an
optional 17x8 with a 235/45-17.
I would look for a nice 18x8.5 wheel with 245/40-18s
Originally Posted by 4runnin
Hi,
I just got a 99 gs4, and im thinking on gettin some new wheelz. I wanted 17's so the ride quailty is still good, but I really like the way 18 look. What I was wondering is if i get the 17 with 215/45/17 will it look to narrow?
http://www.dsm.org/tools/tiresize.htm
If you have ANY interest in your car's handling, you cannot put 215s on your car. As far as looks, in profile it may look ok but from front or rear you'll look very ghetto.
You'll have crap for handling and damn little traction in a straight line. From a ride standpoint, 20s with a tire with low enough profile so as not to significantly alter your speedo/odo readings will turn your GS into a coal cart unless you plan on going with coilovers, too. Remember that your tire sidewall height is as much a part of your comfort and handling equation as are the springs and shocks (with which the wheel/tire combo is designed to work).
But it's your car............
Hi,
17" gunmetal
Thoughts, comments?
Thanks in advance![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
17" gunmetal
Thoughts, comments?
Thanks in advance
![Thumb Down](https://www.clublexus.com/forums/images/smilies/thumbsdown.gif)
Then I wanted to upgrade the wheels for looks and also a little better performance, but still wanted to maintain the comfort.
I was going to buy the stock 17s or go to 18s. My wife said if you're going to spend $ for wheels, might as well get something different and nicer , so I ended up with 18s
![Woohoo](https://www.clublexus.com/forums/images/smilies/woohoo.gif)
The ride is slightly rougher, noticeable on bumps, but the handling is so so much better.
LIke many members mentioned, don't bother going with anything less than 235.
If you want to be conservative, the minimum is 235/45 for 17s and 245/40 for 18s
But if you upgrade your wheels, at least change your shocks. It's definitely night and day, a lot less body roll when you turn and still lexus-comfortable.
Good luck, let us know what you decide
The wheels you chose are very small, maybe ok for an IS, but I would stay away for a GS.
Find something in 17x8.
Hi,
17" gunmetal
Thoughts, comments?
17" gunmetal
Thoughts, comments?
Thanks in advance
Here are those volks
https://www.clublexus.com/forums/att...id=37322&stc=1
https://www.clublexus.com/forums/att...id=26736&stc=1
Then here is a pic of aftermarket 17's
http://www.ronalusa.com/cars/orig_pix/lexus.jpg
Here are some 20's-....perfect
https://www.clublexus.com/gallery/da...CT0666-med.JPG
and 20's see the difference.....worth just waiting cause youll probably be happier in the end.
