Nak stereo cuts out at high volume
I've had this annoying problem of my Nak amp cutting out for a few seconds...makes this aweful clicking sound...then its back on and ok. This will continuously repeat if I leave the volume up. Always happens when I'm rockin it loud
and the outside air temp is 80+ degrees. I notice the front-end face inside the cabin is very warm. Never happened in the cool fall or spring weather in New Hampshire, but now living in Florida it a real issue. If I leave the volume down it never cuts out. Definitely a cooling issue on the amp or frontend...both if they're integrated.
Wondering if anyone else had this experience with their Nak system and was able to fix it. I'm happy with the stereo...for now. Plan to upgrade it someday.
![Rock On](https://www.clublexus.com/forums/images/smilies/rockon.gif)
i had this same problem...the conditions for my problem. We were sitting at a park with the music loud and the trunk closed...i opened the trunk when it started happening and the amp WAS FRIGGIN HOT!!!!!!!!...i mean smeltering....so...i think most likely its a cooling issue with the car sitting still...correct me if i'm wrong but i think there are some exhaust vents in the rear qtr panels, but when your sitting still there is no air movement
i have the same problem w/ my gs430, it has the mark levinson. i purchased an amp from a dif member and it did not fix the problem. i can listen to it at a good volum just cant turn it up 2loud
Originally Posted by Ali Hamed
did anyone find a solution for this problem
I'm personally saving $$$ for a stereo upgrade and mounting amps in the trunk. I need a better setup to rock at high volume!!! It would be easy to get cabin air into the trunk.
"Clipping... ten yard penalty."
Sounds like the amp is being overdriven and is clipping. That's the Nak for you. I (and others) have found that it will do this at volume **** setting clockwise of about 2:00.
Time to upgrade!
Time to upgrade!
Time to upgrade!
Time to upgrade!
fillerf
07-11-18 04:54 AM
