your thoughts on my s2k custom bracket (finished S2K retrofit pix on bt pg2!!)
ok welp after much long debate im going to partially scrap this design... instead of building the whole bracket for the projector i plan to take a page off of aristo 161 diy,, i plan to reuse the reflector bowl mount the s2k projector in it and then fill in the gap with the my design just downsized to fit the bowl
Yeah thats what I do with all retros, reuse the bowl, look in my gallary I got alot of pictures. I dont see why you wanted to make your own bracket. At first I didnt realise what you ment I thought it wsa purely for decorative purposes. But if you actually did take the hard route then your bracket has to be made out of sturdy plastic in order to maintain the projectors weight with heat. If your there is alot of flex in your bracket then you will see your projectors cutof fibrate when you drive. All you do is cut a hole about 3 inches in diameter and the original 9006 bulb ring would be your center then just drop the projector in there and use masking tape to hold it in place, then position it as even as possible, both horizontaly and vertically and use regular j/b weld. WHen you use j/b weld let it stand for 15 mins, it will be much easyer to work with and it wont drip inside.
well i cant decide whether i should paint the housing a glossy black maybe grey or keep it oem and have it shinnny... im feeling the OEM look but painting it black would surely show off the mod more
edit: and my car is white hmmmmm tuffy
edit2: pix , the bezel around the projector isnt in place its just hanging there for this pix
mannn!!!! i totally messed up i didnt have the headlight mounted down right, when i was adjusting the rotation of the projector... luckily it wasnt dried completely i yanked it out and sanded off most of the jb weld going to redo it again.. bbl
looks clean. good job. paint the housing black and call it a day
first the back side:
then the front side:
used meguiers cleaner wax to clean up the lense, i let my friend borrow my 3m cleaner wax gosh i wish i got it back already
now the cut off, side cut off atleast:
AND
finally, the PIZAZZ!!
hey mods if u can, can u change the title of this thread to "finished S2K retrofit pix on bt pg2!!" thanks a bunch
AND
