what to use HELP Lower
What about this set up. H & R claims a 1.4" drop in the front and 1.3" drop in the rear.
Does any one out there have this and if so is there a lot of space between the tire and fender and is there any rubbing ?
Eibach or H & R or what ?
Suggestions please .......................
Coilovers are a bit out of my price range right know so springs are the cheaper alternative.
Morris thanks for the picture. I have my GS on 20" wheels so the gap should be a bit less between the tire and fender.
Does anyone have that set up ( H & R ) with 20" wheels and if so what is the ride like ?
What shocks are you using ?
exclusive matchup
maybe you can look into bilestein and eibach setup, or bilestein with daizen
you can ask todd@tmengineering.net for more info and suggestions i think. he sells them for good prices too
I have the Eibach / Bilstein combo on since I bought the car.
Have over 30K miles on them and love them.
Two finger gap sounds right.
No rubbing.
Bilstein Sport shocks
Front: BE5-2802 $104.30 x 2
Rear: BE5-2803 $118.30 x 2
Eibach Springs
Pro Kit Lowering Spring
8255.140 $290.59
No rubbing.
Eibach Springs
8255.140 $290.59
I have h&r springs but my suggestion is to go with the coilcover because you might need to change your stock shocks soon because it can't handle the drop. It might cause you more money to do the shock later on , cost of labor is high. By the time you change your shocks too
it would be close to the price of coilcover so save up, do the right thing. It happen to me lol....
or change the spring and shock the same time because I did not do it cause i thought my shocks was good but it wasn't and by the time I found out my shock was bad it was too late ,pay double the labor to do it again..
gizbx4
Suspension and Brakes
07-22-08 01:24 PM
