Tension Rod ?
I went to my mechanic to find out what exctly needs to be fixed on my passenger side since it got pushed back about 1 1/2".....so my mechanic puts my ride on the lift and told me that the lower control arm and the tension rod have been bent back, so these parts need to be replaced ...I called lexus and they dont know what the tension rod is they say it has a different name....any one have a diagram of the set up so that I can see what part I need or website
thanks
Erick
thanks
Erick
Originally Posted by lexforlife
it mounts just under floorboard and runs dia towards the front correct , if so thats your castor arm
this is the arm but this is for the driver side
the one that is sticking out on the right
![](https://www.clublexus.com/gallery/data/500/endless61.jpg)
I wish I could get a pic from underneath to be sure
You've got a second-gen GS? The photo you posted does not appear to be a GS front suspension - it looks like an SC300/400 front suspension.
On the GS, the fore-aft running arm is more commonly referred to as a "caster arm" or "trailing arm." I have found these to be quite expensive, about $335 each if I recall. The bushings do go bad on these, and my local Lexus parts guy says they so sell them occasionally.
The side-to-side running arms are "control arms."
well I called Carson and they said They're called lower control arm 1 &2
bob
i replaced mine both last year and i paid like 70 each for them looking at my recpt in front of me , the the part name is castor arm or bmw like to call it thrust arm
