Took my GS4 to the track......
Man, I'm somewhat upset about my times.
My best time was racing Dodge Magnum RT with lowered suspension and exhaust (and whatever that I couldn't see under the hood)
Magnum..................GS400Ltuned shock/springs
RT .0190......................0.341
60 2.307......................2.282
330 6.427......................6.329
1/8 9.724......................9.623
MPH 74.96......................75.14
1000 12.561..................12.452
1/4 14.934..................14.814
MPH 95.87....................95.90
Had the tires set at 33psi and the weather was around 30Celius (about 90degrees?) and very humid. Not very happy about this time at all. My worst time was 15.1 and all the runs were with TRAC off . I think I need to reduce the 60feet time......any tips? BTW the Hemi Magnums best time was 14.7
was the PWR button on? my best 1/4 mile time on 18" rims was 14.65...this run included my RT of .101. look at that magnum's RT of .0190, thats excellent! (and if the RT was even .190, thats still great.) if you can improve your Reaction Time, you will see improvements across the board. my worst 1/4 mile that day was 14.9
I know I am new here, but reaction time only means that you get out first or the other guy does. Your 1/4 mi time starts after you break the lights. You could sit there for seven seconds and still turn the exact 14.65.
My Aristo V300 might be a bit different from your Lex GS, however, here is what I do :
Left foot on brake
Right foot on throttle
Traction control off
Engage in L gear
Build revs to 3000-4000 rpm, left foot on brake holding car.
Launch on lights!
Shift L to auto D mode and let the gearbox change gears for me.
Best time 14.1s with my boost up.
Left foot on brake
Engage in L gear
Launch on lights!
Originally Posted by Chigga
were you at Cayuga?
Don't worry about the time, this weekend is too humid, 14.8 is actually pretty good time for this weather.
i never knew that! you learn something new here everyday! welcome to cl!
Originally Posted by liquidsilver
Yeah, that's what I thought too. Can anyone confirmt this? One of my my reaction time was like .030 and I still ran 14.9.
Reaction time is the time that it takes from the illumination of the green bulb to the time that your car moves out of the second beam in the staging light sequence. Most tracks have converted to a format wherein a perfect light is .000. However, for tracks that have not converted to this format, the reaction time is the measure of time from the illumination of the bottom yellow bulb to the point at which your car moves out of the second beam. This, depending on the delay the tower has in the system, is usually .400 or .500 of a second. So, a perfect light on a .400 tree, is .400.
However, as an example, in a "heads up" race, assume the following: A car that can run ten seconds flat in the quarter is racing a car that can run the quarter in fifteen seconds. They both stage, and the lights drop. The car that runs the fifteen has a perfect reaction time, while the other driver sits (sleeping, presumably) for six seconds, then takes off. The slower car will cross the finish line, thereby tripping the beams, in exactly fifteen seconds. The faster car runs the quarter mile in ten seconds, so his ET will read 10.00, but because he sat so long at the starting line, the slower car will have crossed the finish line one second before the faster car. In this scenario of heads up racing, the slower car has won the race. In "bracket racing" the ET is taken into consideration, and the slower car will receive a green light before the faster car, and if everything is perfect, the two cars will cross the line at exactly the same time. However, due to inconsistency in reaction times, and car performace, there is a winner 9999 times out of 10,000.
Too much info, right?
Originally Posted by RRocket
I go to St. Thomas often....wouldn't mind meeting some fellow CL members there...
I may go this weekend with a friend, I want to see how his 540 go against my car.
hey, I think that's a good idea, I know few people off MaxBimmer may want to hit up either Cayuga or St. Thomas , and we can shut those 540 drivers up .
bbong
IS F (2008-2014)
08-12-16 07:13 PM
verylost
Wheels, Tires & Brakes Forum
04-11-05 10:10 PM
