what's the BEST suspension, yes the BEST
WHat is the best suspension? coilover? ( i am sure it's not just shocks/springs.) what kinda of Coilover? Blitz? Tein? HKS? I want performance turning/handling ability like BMW .. help!! thanks
Well if you want to go full coilovers...the Tein's (CS), H&R's and Apex coilovers are all good...
I don't think any single one of them can be labeled "the best"...they're all excellent. The advatange of the Tein's is that they offer adjustable dampening...
Also, do the TRD STB, Sways, and LCB. I would also do a rear STB which TRD does NOT make (I picked the Carbon Fiber Ukyo Katayama UGO rear STB and I've been considering changing my TRD STB to a the UGO one STRICTLY to match front to rear...so I might be selling my front STB which I'll kick down to a fellow Club Lexus member for cheap)
And to tell you the truth, if you installed the TRD suspension parts (STB, Sways, LCB) and the rear STB (UGO, Carbin, etc.) and kept your L-Tuned spring/shock combo, you'll have better than BMW handling...easily...
manaray:
how much would it cost for parts / labor to do the "ultimate" suspension mods you have listed? If we could not afford to do them all at once, what order would you do them in?
I have Eibach springs but stock shocks. I have heard the Tein coilovers are pretty darn expensive. Help us out with your advice.
how much is the Tom complete set?
i have the Tein's right now... i'm pretty satisfied except for this annoying clunking sound coming from one of the rear coilover. the tein's cost in the neighborhood of $1400.
You need to define what your needs are first. What kind of driving do you do and where do you do it.
The best performing suspension might have 800lb springs and double ajdustable Konis but also knock your teeth out everywhere except the track. Even with the Tien coilovers you could likely order different rate springs. However, if they sell a street set up, I would defer to their engineering instead of your own.
Bottomline, even a moderate perf. street suspension is hard for the average driver to exploit. I would highly recommend more negative camber up front (no more than 2 degrees) and in the back if you can. It will wear tires faster but is the only way to really rid a car of understeer.
You should try to find some guys in your area to ride with so you can compare.
$4,400 whole set.
http://l-tunedparts.com/html/partsordering-toms.html
that's suppose to be Carson Toyota's site I assume (related to Steve @ Carson.) Maybe he can get some SPECIAL pricing for ClubLexus?
on that website, the picture of that ADVOX complete kit is the pic from the set for the Altezza. Aristo kit is different, and the STB won't fit the GS300.
what's included (Japanese translation)
Upper Performance Rod Front (STB)
Suspension Member Brace Front
Suspension Member Brace Rear
Lower Body Strengthening Brace Rear
Upper Performance Rod Rear (Rear STB)
ADVOX-Sports coilovers (special setting for complete kit)
First off, you've got 20s, which aren't designed for great handling.
Second, my L-Tuned setup with TRD sways and braces easily out corners my neighbor's 540i with sport package. Yet my car is still comfortable.
Third, racing coilovers will be rock hard and with TRD sways your car will corner FLAT, *BUT* you'd better not have any weak dental work because it will fall apart in the jarring ride.
Hey Globe,
You notice everything Tom's didn't have the Advox GS pic yet, so we used the Altezza.
Yes, clublexus members get special pricing. This is a Tom's Racing kit, so not everyone will need something this demanding. This is probably the ultimate set-up for a GS if you have the $$$
And because of my agreement with Tom's you need to email me for pricing.
Bobcat - I would do the TRD "Group" first...the STB, Sways, LCB and Steering ECU (if your GS needs it)...it should cost about $100 - $200to install the Sways, LCB, and ECU...and the STB you can do yourself...figure it'll be around $1000 or so for all the parts...
Then I would go with the lowering...the Apex coilovers are the least expensive of the bunch but they're excellent (from what I've heard). Around $1400+ plus a couple hundred to install...if you were closer, I would take you to one my "hook up" shops and they could give you a better price, but Maryland is little far to drive! ...
The less expensive route to go is spring/shock replacment (like L-Tuned)...but you don't get adjustability (height OR dampening) so you're stuck with whatever height it comes out to...but it's only like $500-$600 for parts (steve or gs4will can give you a good price)
For strict handling, I think for MOST people, the TRD "group" will be good enough (even on stock suspension and tires). Once you get the rims/tires, it'll handle even better. Lowering (via spring/shocks or coilover) will take it to the next level...
Bob, since I've talked you in more detail about what you want, I would say just go with the shock/spring combo (L-tuned or otherwise)...OR you can go with the Lsportline setup which allows some height adjustment...
As for the Tom's setup, it's a nice, complete setup! But I wonder which coilover it comes with...comfort or sport.
Had this kit come out when I did all my suspension mods, I might have gotten it...hell, I still might get it...
Originally posted by SUPRATRD
Hey Globe,
Hey Globe,
do those pieces sell individually? Or is it easier to get the TRD pieces? Other than the STB, everything else TRD will fit the GS300 right?
Forget who makes em but there are air shocks for the GS that are fully adjustable height and stiffness. You can go from so stiff that it's like your wheels are welded to the frame to stock like softness, from the ground to stock height and all at the touch of the switches.
Someone posted a link to their site before, might check the search feature but they are probabl around 4k, the hydro pumps take up the wheel well but that's it, not bad for fully adjustable at the touch of a switch, no scraping over driveways or speed bumps.
