Cat back vs muffler
Are there any significant gains from a catback exhaust? I hear they are generally louder than just mufflers. Does the performance of the catback and mufflers differ? Has anyone had experience with the Blitz Nur Spec exhausts? Thanks.
-Andy
-Andy
B/c of the backpressure, a catback exhaust is theoretically supposed to increase performance, whereas a muffler could be as simple as just a different looking pipe, which would in that case only change the aesthetics of the exhuast.
GX and 2IS Moderator
You could gain by having an all stainless vs. alloy, or switching to a larger diameter. Not too much bigger or you'll really foul things up. I'm sure others with more experence can correct me, but 2 1/4 to 2 1/2 is probably okay, but any bigger jump you may actually lose performance unless you make other engine management systems mods as well.
Hey Andy,
Jazziz has a Blitz Nur Spec on his GS4. Having heard it I did not find it overly loud, and I'm not a fan of loud exhausts. Typically, you won't get a large hp increase from a cat-back, maybe 4 - 6 hp.
Eric
Eric
Presario,
I believe Greddy is one of two that sells a catback system. In my opinion, a catback system provides a little bit of a performance gain as compared to a muffler system but definitely NOT a bang-for-your buck mod.
HOWEVER, most muffler systems cost as much as a GReddy system which is a catback system. In this case, it becomes a more-for-your money mod.
Buying the H-pipe alone is probably not worth the cost. Removing the cats is another story but it is a legal no-no here in SoCal so I know you and I are in the same boat. WIth my previous car, the 300XZTT, replacing the cats with a testpipe yielded almost 15 extra HP on the dyno! So unless you are planning a turbo upgrade, removing cats is not worth it too especially in smog-conscience California!
Brent
Brent
maxgee
08-23-07 02:47 PM
