engine light on
engine light on
hey guys,
i just installed an intake system for my 2000 gs300, i notice that the engine light is on, it's on for a few days then off and back on fews days later, any glue why this happens, thanks alot
Originally Posted by GTFM
when you guys installed you guys left the battery cables on ????
Originally Posted by vicestan
What kind of an intake did you install? srt? because if you installed an intake w/o a upgraded intake ecu you will get the cel light no matter what you do.
I've worked on a few different types of cars and they "usually" have maf's.
You reset the computer because after the intake install - the computer is reading more air (vs stock air filter) and is throwing a code. When you reset the ecu - it compensates fuel for the increased air flow.
Someone correct me if I'm wrong
The intake ecu sensor is located right on the intake pipe, thats why the srt intake comes with an upgraded one which tells the main ecu that the air flow is normal, when in fact its not , its way more and thus it produces more power. The srt intake I think it goes for around 500 .
Originally Posted by runyun
Yea. What's wrong with that? Not like you're going to blow anything up
I didn't know we had "intake ecu's" in our cars - where's that located at? I want to know who sell's "upgrade intake ecu's."
sorry whenever i think of intakes i think of SRT
and having to solder wires
LoL didnt you read the previous posts, the engine light wont go of, with more air in the engine I believe the combusion is running to rich and thus showing a problem. If you were to go and scan the system for problems it will tell you its a problem with the intake. Srt intakes come with a chip that tells the ecu that there is nothing wrong. I think that if you run a intake with out a moddified intake chip then you actually might be loosing power , If I remember correctly the butterfly will restrict the air flow or something of that nature.
