Noise when i press the gas :(
Originally Posted by Alexus-Kia
It does it in drive P, N it sounds crazy!! Is it expensive to get fixed?
Originally Posted by chuckb
is it a metallic sound, or a water swishing/gurgling sound?
Metallic like how??
IT almost sounds like a screw pinging around or like gurgling sound more or less!! i will try the coolant thing in the morning! i'm going to read those other post snow!
Metallic like how??
alexus-kia, I am experiencing the same sound (metallic raspy noise) on my gs.300.02. When I took it in on Tuesday the dealer stated that they couldn't hear the sound. The sound seems to be amplified in parking enclosures and requires sensitive hearing (she's my baby so I know her cry). Anyway I went in to the dealer and took a test drive with the mechanic and identified the sound. The mechanic said it's the heat shield/exhaust manifold around the catalytic converter. They will be replacing it next week under warranty. My baby has 60K on it, however due to federal regulations components around the catalytic converter are covered to 80K. Also I have a great relationship with lexus service tech so that helps. Once replaced, I'll let you know if the sound goes away. Good luck identifying the source of your rattle.
Cheers euge
gs.300.02 mac interface coming soon.
Cheers euge
I have the same problem in my 2000 GS400. This problem has been discussed in the past, but I can't recall if anyone suggested any solutions. The sound is "gurgling", more like runing water. Once I thought it was a lose screw in the intake manifold, but didn't find anything. If there is anyone out there with a similar problem please suggest a solution. I am sure we are not the only once. Thanks!
Sorry guys i didnt get to try to refill the coolent (at the least of things 2 do) because my dog got sick and is in the hospital(getting charged a arm AND leg) And.....
Not to sound stupid but I DONT KNOW WHERE THE COOLENT GOES IN AT!
If someone can let me know that\ll be GREAT!!!
Thanks
Thanks
Everything in Moderation
Put coolant into the top of the radiator in the front of the car. The stock radiator cap for the GS has a yellow sticker on it. NEVER open the cap when the engine is hot - steaming hot water can spray out all over you. The coolant you put in should be the same type that is already in there. The red Toyota coolant is stock and is prob what you have. It must be mixed 50/50 - 50% coolant and 50% DISTILLED water (get it at supermarket, etc.). Also fill the coolant reservoir up to the full line. The coolant reservoir is the white plastic small tank that is next to the radiator, you'll see a small hose going to it from the radiator.
if it is the bubbles in the coolant(which I'm still thinking it's the heatshield), I think you would need to let the car run with the cap off and the heater on for a few minutes. a little messy, but it will give the air a chance to circulate out.
ok will do in the morning where do i get the toyota coolent from....(only toyota )
Thanks
Thanks
DMPesso
04-23-15 05:53 AM
ml30306
04-01-15 07:43 PM
