lower ball joint DIY???
Originally Posted by ILOVEGIRLS
i cant seem to find the thread. i have been searching, does anyone have it saved as a link? thanks
remove cotter pin
17mm and impact
remove castel nut
separate ball joint from hub
and depending on what year it is there is 2 more nuts witch are both 17mm
this is the one i used
https://www.clublexus.com/forums/sho...wer+ball+joint
Do not start this project without the arm puller. You WILL need it.
Originally Posted by corkycal
"NO IMPACT WRENCH!!!!!" you need a puller to do this job.
es30000000
12-04-12 07:56 PM
