Help with headlight cutoff
i have the stock halogens and for some reason, my drivers side is very high. the bubbles for both are dead set in the middle, but the passenger side has a good cutoff line whereas the driver side kind of wanders upwards a bit. It got a bit better with soem adjustment but i still have a pretty awkard beam pattern. Any tips on aiming them correctly? Do i have to mess with the Left or Right adjustment too?
well if the bulb is in right than yes your going to have to adjust the up an down which i think is the top screw. i guess compare to the other side once you have it level to see if you need left to right adjustment aswell.
