will these fit my oem muffler?
there Magnaflow Stainless Steel Tip Double Wall 3.00" x 7.50", 2.25" ID
If not what size do i need i have no idea??? thanks!!
![](http://performancepeddler.com/images/35122.jpg)
Originally Posted by LB Lex
Get it welded, it's cheap to do it and you don't have to worry about it falling off.
Make sure they align them straight and maybe tilt them closer to the bumper, but not too close.
Have them hold them first while you stand back and take a look.
When I was on my 16's with 55 series, they scraped going into any incline, driveways...., worst with passengers in the back.
Now with 18's on 40s, unlowered
![Slap](https://www.clublexus.com/forums/images/smilies/slap.gif)
lower
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
ok thanks yall!! What is the stock muffler size opening so i know how wide the tips have to be, is it 3"??? i tried to search for it! No luck!!
also is it called a muffler of exhaust?????
How much are those running for? May I suggest Borla Tips? You can PM Drewgs4. He got few sets of the borla. You can get them round or oval.
I recently purchased a set from him. They are modified so you can just bolt it on yourself if you dont want to weld them.
also is it called a muffler of exhaust?????![Uhh...](https://www.clublexus.com/forums/images/smilies/1387914497.gif)
