Having issues taking off my steering wheel. Please help.
Hey fellas,
I'm trying to remove my steering wheel, but I'm having some problems. I removed the airbag and the 19mm bolt in the middle already.
I then tried using the oem steering wheel remover https://www.clublexus.com/forums/sho...l&pagenumber=5
But here's the problem. I screwed the two side bolts in, and started to screw the middle bolt in to pull the steerring wheel out.
After a couple of revolutions, one of the side bolts begins to get loose and seems to be stripping. I tried screwing the side bolts all the way in, but no dice, one of the side bolts seems to always get loose while the other stays tighted inside. If i keep trying to screw the middle bolt, one of the side bolts eventually will come out. I have no idea what i'm doing wrong. Please help.
