A/C pass. side blowing hot
Hello from Wash, DC, where it's 100+ degrees F:
My 99 GS4 seems to be blowing air that is much colder on the driver's side than on the passenger's side. Yes I have "dual" button off, and both sides are set to max cold. No matter what I do, the pass. side doesn't get as cold as the driver's side.
I had a previous similar problem with another car of mine, and it was the a/c blend door being stuck in a paritally open position where it let in some hot air. I assume it's the same problem in my GS.
Can anybody recommend how to reset it, or how I can get to the blend door (if that is the problem)?
Thanks,
Bill B.
99 GS4
85 Volvo 240
77 Bandit Trans Am
67 Olds 442
Thanks,
Bill B.
99 GS4
85 Volvo 240
77 Bandit Trans Am
67 Olds 442
Master Thread Closer!!
No idea...seems like a blockage somewhere....but check ur a/c filter...have it cleaned out. Its located behind the glove box....check ur manual...it shows u how to remove and clean.
goodluck.
goodluck.
