Side mirrors moving down in reverse
exclusive matchup
Originally Posted by blacksc400
AS I know, LS98-00, Lx470, SC430 and RX330 have this option. Even my previous LS430 UL doesn't have it!!
Originally Posted by rominl
really? umm i gotta go check it out, somehow i thought the ls430UL i drove had it. i think you have to put the mirror adjustment botton either to driver or pessenger side? i know on my sc430 if i put it in the middle, nothing tilts down
You are correct. The switch has to be in the driver or passager side position. If it is in the middle it will not work. I found this out myself. I thought it was broken in my 2000 LS, then i figured it out.
GS mirrors don't move because .
duh.
duh.
i know, so hard to keep it on topic
Registered User
...well, might be ghetto rigging it...but maybe somebody can rig up a circuit that can switch between the first and second memory settings (first button = normal , second button = normal, but with mirror pointing down). When the circuit senses the car is in reverse, it'll activate the second button...then when its out of reverse, it reverts back to the first button. Of course, you'd need to override the "safety" triggers (Shifter in park)....and you'd lose the ability to use the second memory settings for someone else.
