What the hell is this?
Guys,
Had to take off my front wheels to install my bodykit. Anyway, after I installed the kit I put the wheels back on. When I was driving home I was getting some steering wheel vibration. So, I thought I had not tightened the lugs properly so I stopped and re-tightened them.
Still didn't help so I got home, jacked up the car and spun the drivers side wheel. Well, it wasn't spinning properly, looked like the wheel was bent. I knew my AME's weren't bent so I pulled off the wheel and this fell out.
Is this something that was on the inside of the wheel or was this mounted on the hub??
I am driving with it off and everything is fine. No more shake.
So what is it and do I need to replace it??
Thx.
Jonny
![](https://www.clublexus.com/gallery/data/500/medium/Picture.jpg)
Thx.
Jonny
That's your centering ring. When you reinstalled you wheels, it looks like you did not have your wheel lined up properly to the hub - that's why its all bent up. You should replace it, it helps to keep your wheel centered properly on the hub.
its definately hub ring, when putting wheel back on when you were tightening lugs it pinched your ring and that is the disfigurement on the ring,
wheres the pics of the kit, your killing me
Tomorrow night!!
Jonny
yep, hub centric ring.
Believe it or not, last weekend I found out that one of mine was bent
I suggest changing it, b/c it causes your front end to be out of balance and rattle at high speeds.
Originally Posted by Dx3
Thx bro! U still rockin the Legend? U going to NOPI?
Jonny
Jonny
Yeah... Ide really like to get into a 2nd gen GS or even a 1st Gen GS.... OR a 2nd Gen LS.. LOL Soon. I still would like to keep my Coupe though. Is been really good to me.. (i'll post some pics once I finish it)
I will be at Nopi.. If your w/ the SELOC guys i'll cruise by...
