well i did it.
Old 08-08-05, 04:10 PM
Dee
Dee's Avatar
Default well i did it.
i have been doing some reserch for the past month or so and i found out that toyota made a 4.27 gear rear end diff. so i found one and went to work on it. i just got done putting the baby in the car and all i have to say is one word WOW!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! the car gets up off the line so fast it's not even funny. i think i will be buying rear tires very often now. the swap was not to hard at all to do the hardest part was to take the 4.27 diff over to the rear end shop and get the yolk changed on it.
Old 08-08-05, 04:21 PM
LEXISM
LEXISM's Avatar
wow great find
Old 08-08-05, 04:26 PM
joshoowa
joshoowa's Avatar
was it off a sc300 or is that a 4.1
Old 08-08-05, 04:31 PM
chuckb
chuckb's Avatar
congrats, sounds quick
I'll be the first to ask- do you have limited slip too or stock open differential?
Old 08-08-05, 04:36 PM
Richie
Richie's Avatar
Cool mod
Old 08-08-05, 05:04 PM
LXOGOOD
LXOGOOD's Avatar
Dee, so how far off is your Speedo? 10-15mph?? I bet those gears rip through the rpms...
Old 08-08-05, 07:45 PM
49GS400
49GS400's Avatar
Congrats on the mod. Yeah as LXOGOOD stated, How off is the speedo? Also, have you checked the how far the speed limiter is? Do you have LSD installed also or just the gears? Sounds like a great mod.
Old 08-08-05, 08:08 PM
GS wanted
GS wanted's Avatar
Thumbs up
4.27? damn, now i can have more fun the next time i'm at your shop. (ha ha) i'll be calling you soon man. just been busy but i already have most of the parts. still waiting on the wheels though.
jd
Old 08-08-05, 08:19 PM
LasVegasGS
LasVegasGS's Avatar
What do you think your top speed will be now?
Also what does your car Idel at now?
Whats our stock GS4XX gears?
Old 08-09-05, 06:14 AM
corkycal
corkycal's Avatar
i guess it's not a freeway cruiser anymore. is this off an offroad car or truck that needs higher gears?
Old 08-09-05, 06:29 AM
chuckb
chuckb's Avatar
gears have nothing to do with idle rpm. did you mean cruising RPM at a certain speed?
stock GS4 is 3.27.
Old 08-09-05, 10:49 AM
rominl
exclusive matchup
Senior Moderator
rominl's Avatar
very nice. yes the idling speed won't change, that shouldn't matter.
stock is 3.26 or 3.27 i forgot
the speedo off is ALWAYS a % of the speed you going, it's not a constant value. if going from 3.2x to 3.76 is about 3 to 5% (i forgot), going to 4.2x would just be another 4% max i say. i believe when my speedo says 80mph, i am going at about 84mph, so with the 4.2x, you are going at around 87mph when it says 80mph. 10-15mph that's way too much, you gotta be using 5.xx i think
and about top speed, stock is 149mph, and with the 3.76 it's about 130 to 135. with the 4.2x? maybe 120? this is just a rough guess though
Old 08-09-05, 12:22 PM
Dee
Dee's Avatar
well yesterday i was driving 45 mph and i drove by one of those signs that flash your speed and it said 45 just like what my speedo was reading. but today i will drive by a little faster to see how far it is off if any. on the freeway yesterday i hit around 120mph and the speed limiter didn't kick in yet today i will try to go faster and see when it kicks in. my stock gs 4 gears where 3.22 and yes this rear end is off of a 93-97 sc 300 automatic. if anyone needs one done in my area i can install them for you.
Old 08-09-05, 02:29 PM
Received 2,524 Likes on 1,660 Posts
No Henry, I believe gearing doesn't change the speedo reading at all because that comes off speed sensors on the wheels, not the driveshafts.
The only thing that changes speedo readings is changing tire diameter.
Yes, lower final gearing will decrease top speed.
Old 08-09-05, 08:45 PM
rominl
exclusive matchup
Senior Moderator
rominl's Avatar
)@&*%)(@*^)(&@**^@ yes you are right paul..... i don't know what the heck is wrong with me..... why i always mix up between bigger wheels and different rear gear ratio..... sorry, my bad my bad.... the speedo will still be exact. paul is right, it will only change if you have different wheel diameter
@_@
Quick Reply: well i did it.
