Relocating the battery to the trunk??
Has anyone ever relocated there battery to the trunk for better weight balance.
I know there are kits out there to do this but was wondering if any of them were designed for the GS.
I always feel the GS is a bit top heavy. This is not a problem normally
but in the case of my GS I see it as a problem. I have the supra spare in the rear but would really like to put the battery in the back. Both the benz and bmw have it this way.
Originally Posted by TheSupe87
How much does a normal car battery weigh? Willl it really make that much of a difference?
Also - how is the weight balanced in these cars? Is it 50-50, 70-30, or is it more like my car 90% to the front and 10% to the back, making an interesting ride in the winter....can we say- SUbwiifer Boxes and cynder blocks to weigh down the back end?
and i think the battery could make some difference. a battery is like what, 80lb? it's one heavy thing, shifting that to the back is a big 160lb swing easy. a lot of performance car do that. heck, on the rmm is430, they put the battery in the back i think (or the tte one?)
but i think it's a lot of work. drew, if you wanna do it, maybe you can just get one of those racing battery which is like 20lb? if you don't run on your batter most of the time (when the car is running, everything is off the alternator anyway), it's a good setup
actually, on our cars the battery is on the passenger side on the firewall which is closer to the middle of the car than in most cars. It is also on the opposite side of driver to even things out more. I don't think it is as big an improvement as a car that has the battery sitting in the very front but it can't hurt to move it to back.
and Henry-if your battery weighs 80lbs, that thing could power a golf cart.
Here's what you'll need to do.
Battery box w/ tie down
sealed battery (optima type)
You can run a 0 gauge or 4 gauge to the back from your alternator
0 gauge ground wire grounded to trunk.
4 gauge ground wire from battery to the engine bay with a distribution block to mount factory ground locations
Extend the 8 gauge (please double check the size) fuse box power wire to the back trunk
Make sure you have a circuit breaker on the front enginebay incase you have to shut off power or to prevent a short.
Hope I didnt miss anything.
The additional weight of the wiring and hardware necessary to do this conversion would most likely result in a loss of performance...which is what i'm assuming you're trying to achieve here.
Most people that do the battery relocation is for weight transfer in their race cars.The battery is mounted on the passenger rear to help plant the rear wheel when launching.NHRA also requires that a battery shut off switch be mounted as far rear as possible to shut it down in any emergency.I am in the process of doing this to my toyota starlet and it's not hard at all.Good luck if you want to do it.Look at summit or jegs for some nice batteries and kits.
I used to drive an SC400 and was looking to relocate the battery to the trunk. That made sense at the time. However, I switched to a GS300 when my SC400 was totalled. I promptly noticed the improved location of the battery (as some have already mentioned).
Currently, I cannot justify (at least in my mind) relocating the battery to the rear. Unless you're replacing the sound system with a mega amp system! There is also the coolness factor --priceless (of course).
I would recommend replacing battery instead. The stock battery weighs about 40 ~ 45lbs. A drycell would weigh as low as 14lbs (depending on size / reserve capacity). That's a good chuck of weight for the money. It also frees up space under the hood; drycell batteries are radically smaller than regular automotive batteries.
Hawker / Odyssey makes military grade drycell batteries -- the best in the business IMHO.
Good luck!
Good luck!
and Henry-if your battery weighs 80lbs, that thing could power a golf cart.![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
I have decided against relocating the battery to the trunk. To much effort involved with very little gain. I think a better idea is to get a lightweight racing battery as many of you already suggested. I do not think this would be a good idea if your GS is your daily driver which in my case is being used as such.
I will stick to my optima battery which has proven to be one awesome battery.
Safety First... The battery fumes must be considered if a standard wet cell is moved to the trunk. Battery fumes are hazzardous to the health, not to say, explosive. The trunk must be sealed from the interior and vented to the outside. Current drop will be substantial across the length of the large diameter wire to the starter solenoid from the trunk, regardless of which type of battery is used. This wire(cable) is not fused and in an accident might create a fire.... Good ideas anyway !!!
Has anyone done this? I know the battery is located behind the front passenger tires, but it still provide signigicant weight to the front shocks. Adding weight by relocating is not so bad considering how heavy the front feels.
Losing 200 lbs in the front would be excellent if possible...or even distributing some weight to the back would be beneficial (even if it's behind the rear tires).
I think JeffTsai is doing it for his 300, hopefully we get an impression.
