D.I.Y. Silent Intake
I bought the intake of Ebay and cut it upt to fit the stock box. On the intake I got there was a little leg on the back of the bend to attach a vacuum hose I just used a T fitting from o'reilly's and attached both hoses to the fitting then routed the hose that was supplied from the fitting to the leg. It has been working great.
Dang, talk about bringing a thread back from the dead lol. Anyways, the two hoses are for PCV and EVAP system. They technically don't have to be hooked up, and it won't affect how the car runs. However, it's best to have it hooked up so you minimize the extra amount of emissions from your car.
just get small breathers and put those where the hoses go. those hoses do not NEED to be hooked to the intake. one is for emissions and have to do with recycling gases and the other i believe is a crank case breather (new to Lexus, so could be wrong on the second one and don't have it here to look at).
Your right i went on ebay last night and saw a short ram aristo intake for the 400 for like 8.95. I didn't know what the shipping was but it had the pipe,filter, fittings, and the space for the MAF sensor... So it seemed like a direct swap... Looked great except it didn't have the heat shield
Still for 8.95 it has to work like the k&N which cost over 240.00. Maybe i'll order it...
Tony
Tony
