Aristo Mirrors on GS
ok so im in the process of securing Aristo mirrors that fold up when you shut down the car via switch
will these work if i wanted to swap insides
how could i make this work
thanks Guys
thanks Guys
Originally Posted by LEXUS_KID
Hey J I'm quite sure you could figure this one out your the king of "DIY" you'll get there I have faith in ya Bro
Thanks Bill
I was hoping that someone from over there would have some insight
Originally Posted by TLW
damn really
hmmm
richie ..your GS doest have this feature ??
hmmm
As far as I know only the Jap spec cars have this.
It should be a pretty simple retro fit. It's a matter of wiring up a relay to trigger when your key is put into the off position (lack of ignition source). If you want some help with this, let me know and i'll see how I can help you. ...and the opposite when the key is turned back on. So it should work with 2 relays...
man this retro is going to be sick... true VIP with the JP on too !
man... i gotta come over and see this car for myself soon johnny.
btw... quiklex... where in PA are you from?
i'm in philly and I don't see many other modded GS's around... mostly just some dudes with chrome 20's slapped on and driving around...
Master Thread Closer!!
Wow....that would definitely be SICK....SICK....SICK!!!
As for wiring it up, I think tapping into the signal from the motorized steering wheel (same as the ignition signal) would be ideal.
Pete
Pete
Pete
Pete
240sx guys do this all the time. I don't know how the Toyota's are wired, but I can't imagine anything more complicated than a lead wire that's connected to the "engine on" line, such as that on your stereo. Then ground it, I'm sure that's how it'll work. Not like you need a separate computer to control this function. Now, if you want to control this manually, then it'll be even easier. Just run a relay into any Radio Shack switch.
And since the JDM and USDM mirrors look identical, I'm sure it's a direct fit replacement. Unless Toyota has engineering consultants from Germany that believes NOTHING should ever be a direct replacement part.
