1st Gen w/Swift Intake and ECU?
I know that there's an application for 98+ GS300,400,430...but anyone know if the kit for 98+ GS300 will work for the first gen 93-97 models?...same engine but w/out the VVTi right? Info greatly appreciated.
I dont think it would work just because the ECU's are programmed diffrent since VVT-i works diffrently from the old engines so the ECU's might not match up but the intake from weapon R or RMM could work since it doesnt need an ECU and Im geussing that air sensors on the end of the intake are the same so it should fit ad a apex AFC to it and that will solve your air/fuel ratio problem and boost the intakes potential
Im not sure about this though since Im not very familiar with the 1st. Gen. GS's but ask globeclk or some one who knows about the intake systems they might be able to give you a more detailed answer
JBrady
07-13-02 04:40 PM
