ECU upgrade
Negative Nancy
ECU upgrade
well my bro-in-law might be getting either a 98 or 00 GS3..i cant remeber what year..but anyway he was asking if i know of any upgrades to make it alil bit faster and i told him bout the ecu upgrade..now i just wanna know how much HP do you gain?? and does it even do anything significant?? thanks in adavance
Negative Nancy
Originally Posted by Neo
As far as plug and play, there is no engine ECU upgrade. There is an L-Tuned steering ECU but that is about it.
Negative Nancy
Originally Posted by ARISTO*7
maybe you're thinking about the srt intake with the ecu upgrade
Originally Posted by Swift Racing Technologies
The High Flow Intake system adjusts the air-fuel ratio to optimal settings in conjunction with a high flow Intake system. The stock intake system from Lexus has deficiencies in supplying air needed by the engine. Swift Racing is proud to present the first ever High Flow Air Intake for the GS300. This system helps the engine breath much better and gives the car quicker acceleration and much crisper throttle response in the entire RPM range. It uses 3.5" mandrel bent steel pipes and 5061 aluminum heat shield, enamel coated and uses a 5" conical AFE lifetime air filter.
Performance gains: +22HP and +24ft/lb torque. MSRP $545.00
