** Pic of New TT Supra Cailpers, RT Cross-drilled Rotors for GS **
Original CL Sponsor since 1999
This is what I'm putting together for the GS brake upgrade:
(2) Supra TT 4-piston calipers
(2) RT cross-drilled rotors
(1) Factory Toyota TT brake pads (front set)
(1) Impulse SS brake lines (set of 4)
Total price is $889.00, all parts are brand new
These are the same parts I'm using on my own Supra, I'm just trying the Hawks HPS brake pads instead.
The rotors are by Race Technologies, a local Brembo distributor. They are cross-drilled, cad plated and dynamically balanced. Brembo DOES NOT make stock cross-drilled/slotted rotors for the GS, only for their upgraded brake kit.
I had another local company, Impulse Racing, make the GS brake lines to insure fit.
They are some different combos we can make for this:
Hawks HPS front pads add $40.00
RT cross-drilled rear rotors (stock) add $250.00
Sorry I don't have an elaborate photo, I'm on a low budget.
Hey Steve, those look really good. Is it me or are those rotors goldish colored? Can you get them in silver?
I sent you a couple emails to your gonzo email address last night about some other parts, please respond when you get a chance.
Bobcat
Bobcat
Hi Bobcat,
Yeah, that's the cad plating on them. The surface will wear off shortly after some braking, the "hat' part will not.
TRD has some 5 slot rotors available in silver I can do for the same price.
I'll try to pick-up my email from home and get you an answer.
Forum Administrator
![](https://www.clublexus.com/forums/images/ranks/rank-admin2.gif)
Steve,
Are these the same size as stock GS brakes? From prior postings, I've read that some Supra or aftermarket brakes won't fit inside the stock GS wheels.
Also, do you (or anyone) have thoughts on getting this stuff installed by a Lexus? How about if it were TRD parts?
I haven't found a good speed shop I trust in Charlotte, and don't have the time to put these in myself these days.
Thanks,
David
Thanks,
David
Hey Steve...
how much would it be if
1) Supra TT calipers
2)TRD SS lines
3)TRD pads
4)Brembo rotors (Supra TT rotors)
would this be better or about the same... ??? this is what someone suggested I get if I
wanted and low budget brake upgrade.. I personally have no opinion about these
brake upgrades...
2)TRD SS lines
3)TRD pads
brake upgrades...
Guest
Posts: n/a
Originally posted by bLingIn3o0
Hey Steve...
2)TRD SS lines
3)TRD pads
brake upgrades...
Hey Steve...
2)TRD SS lines
3)TRD pads
brake upgrades...
