trouble after changing timing belt
Old 09-25-05, 06:01 PM
GS4
GS4's Avatar
Default trouble after changing timing belt
I just got my timing belt replaced and now the car has a bad shake at idle. No noise from the engine just a shake. Any suggestions on what is wrong.
GS4
Old 09-25-05, 06:16 PM
TLW
TLW's Avatar
bring it back to where you got it fixed ..this the best option
Old 09-25-05, 06:29 PM
sung35
sung35's Avatar
Or if you did it yourself, then get it to a shop to have it redone. I think the timing was off.
Old 09-25-05, 06:36 PM
GS4
GS4's Avatar
I never left the shop. When I was looking around the engine bay I noticed that the maf sensor was a bit loose. It is missing the gasket. Can this cause the shaking?
Old 09-25-05, 06:39 PM
morris
morris's Avatar
yes if the gasket is missing then it can suck air in through the MAF sensor, if this happens the maf would not sense all the air and would give you an incorrect mix. But you would probably get a CEL at some point indicating a system to lean or something.
Old 09-25-05, 06:44 PM
GS4
GS4's Avatar
The check engine light is on.
Old 09-25-05, 07:05 PM
morris
morris's Avatar
Just go to autozone or advance autoparts in the AM and have them read the code, this should point you in the right direction
Old 09-25-05, 07:19 PM
GS4
GS4's Avatar
Shouldn't my mechanic be able to read the error codes?
Old 09-27-05, 11:07 AM
morris
morris's Avatar
yes he should I thought you were already home when I posted that suggestion
Old 09-27-05, 03:30 PM
JPI Racing
JPI Racing's Avatar
You paid him for the job.....Let him fix the problem!!!
JP Importz
Old 09-27-05, 03:58 PM
GS4
GS4's Avatar
Didn't pay him yet, I am worried that he may have damaged my engine and trying to cover it up because he keeps telling me that the car will be ready tomorrow, then that turned into the next day....
Old 09-27-05, 05:18 PM
JPI Racing
JPI Racing's Avatar
I'm sure your guy has a scanner..... Have him scan the code.
JP Importz
Old 09-27-05, 07:04 PM
gcam77
gcam77's Avatar
Default where did you take your car
GS4 I noticed you r in the NY area, what garage did you take your car to? Hope everytings works out ok.
Old 09-28-05, 11:44 AM
ServiceGuy
ServiceGuy's Avatar
not saying you were wrong in not taking it to a dealer, but by taking it to a dealer you have a lot more recourse if anything goes wrong..
Old 09-28-05, 06:21 PM
GS4
GS4's Avatar
If anything goes wrong then I would assume that this shop is responsible for the repairs. How big of a problem can not installing the timing belt correctly cause? Can it be off slightly and not cause damage?
GS4
Addicted
12
01-22-15 09:07 AM
pinoiryder
06-12-14 08:21 AM
Bernie716
GX - 1st Gen (2003-2009)
07-14-11 05:23 AM
MauiGS300
06-13-09 05:43 PM
Lvangundy
05-24-03 08:36 PM
Quick Reply: trouble after changing timing belt
